MotoComposites Carbon Fiber Headlight + Dash Support, Dragster 2014-20177 - MVAgusta.net
 3Likes
  • 3 Post By M Squared
post #1 of 3 (permalink) Old 03-13-2019, 10:12 PM Thread Starter
M Squared's Avatar
Hi Folks,
This is a quick review of MotoComposites Carbon Fiber Headlight / Instrument Bracket (Brutale 2013-2015, Dragster 2014-2017): https://www.motocomposites.com/produ...2014-2017.html (~$210 U.S.D., + delivery).
Summary:
>Lightweight (as expected)
>Surprisingly robust / stiff
>Surprisingly accurate (very little filing / fussing to fit)
>Nicely finished / the weave (pattern, color, gloss, and 'depth') matches the OEM carbon fiber
>Installation, while easy, requires patience (due to one blind bracket bolt on throttle side)
Attached are 2 images of the bracket / support, and 1 of it installed.
Ride smart / safe, and enjoy!
M Squared
mikecr50, Claude and db_509 like this.
M Squared is offline
post #2 of 3 (permalink) Old 03-18-2019, 03:05 PM
I had a lot of MotoComposite parts on my fz. Great products. Might have to add this to my dragster. Thanks for the post!
xxscaxx is offline
post #3 of 3 (permalink) Old 03-18-2019, 05:55 PM Thread Starter
M Squared's Avatar
Hi XXSCAXX,
You're welcome! If you do add one to your Dragster, and would like installation tips, just let me know. The 5mm socket head under the upper triple, throttle side, requires patience, both to remove (you won't be able to see it), and to replace it (it also holds the ignition barrel mount).
The additional attached image shows the thickness of the instrumentation mount.
With kind regards,
M Squared
