CNC Racing Frame Plugs - MVAgusta.net
 2Likes
post #1 of 17 (permalink) Old 02-16-2019, 07:28 PM Thread Starter
Hey All,
I have a quick question for those of you that have experience with the CNC Racing Frame Plugs. I bought a set for my B3 800 a little while ago and have finally found some time to install them. I've noticed there is a straight metal rod which doesn't appear to be needed. The installation instructions don't mention the metal rod at all. Any idea what it is for?Name:  20190217_122704.jpeg
Size:  94.9 KBName:  20190217_122711.jpeg
Sent from my SM-G920I using Tapatalk
Kargo is offline
post #2 of 17 (permalink) Old 02-16-2019, 09:00 PM
MV Arthur's Avatar
Is it threaded on the inside?
2013 F4RR
2009 F4 RR 1078 312
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
MV Arthur is online now
post #3 of 17 (permalink) Old 02-17-2019, 01:54 AM Thread Starter
No thread. Its a hex shape thoughName:  20190217_184515.jpeg
Size:  31.2 KBName:  20190217_184513.jpeg
Kargo is offline
post #4 of 17 (permalink) Old 02-17-2019, 07:56 AM
Doesn't it fit into the hex on the plugs? I'd think it is a long wrench.
db_509 likes this.
post #5 of 17 (permalink) Old 02-17-2019, 11:38 AM
MV Arthur's Avatar
According to the instructions, that's to hold the nut for the frame plate caps. It's on the brake side so you need to feed it from the shift side. I can see the inner hole of the nut is hex shaped, like your mystery metal rod.
2013 F4RR
2009 F4 RR 1078 312
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
post #6 of 17 (permalink) Old 02-17-2019, 08:41 PM Thread Starter
You sir are a genius! The metal rod is the "tool" mentioned in the instructions. As you said, it's used to push the cylindrical nut (or "special nut" as they call it in the instructions) through the frame from the clutch side to the break side. It holds the nut in place until the cap denoted "D1" is tightened on the break side.
Thanks for that! I need to try and touch up a tiny bit of paint and will then fit the caps. Name:  20190218_132815.jpeg
Kargo is offline
post #7 of 17 (permalink) Old 02-19-2019, 04:32 PM
makers_mike's Avatar
Love seeing threads like this. There is nothing more frustrating than sitting down to work on the bike and getting caught up on something.
2019 MV Agusta Dragster RR
2017 Aprilia RSV4-RF (SOLD)
2016 Aprilia Tuono Factory (DECEASED)
2015 MV Agusta Dragster RR (SOLD)
2013 Triumph Daytona (SOLD)
makers_mike is offline
post #8 of 17 (permalink) Old 03-19-2019, 03:02 PM
Skinnyhippy's Avatar
I fitted mine last night. I dont think the instructions could be any more vague if they tried.
I'll give the plugs one ride before they fall out i rekon.
Skinnyhippy is offline
post #9 of 17 (permalink) Old 03-19-2019, 03:20 PM
MV Arthur's Avatar
Use loctite and you'll be fine.
2013 F4RR
2009 F4 RR 1078 312
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
post #10 of 17 (permalink) Old 03-20-2019, 06:39 AM
Loctite As in 'thread lock' or 'superglue' ? Its more relying on the rubber rings holding tight inside the cup - just cant see it lasting long.
