Here to the least reliable bike in the market... - MVAgusta.net
 2Likes
post #1 of 23 (permalink) Old 08-29-2018, 09:14 AM Thread Starter
Maser's Avatar
Angry Here to the least reliable bike in the market...
For those looking at getting a 2016 Dragster, this is what I have experienced just in the last 3 months..
This is my wife's bike with only 11,000kms on it, never abused or tracked.
- Rear brake stopped working, fixed but about to go again.
-Rear right turn signal died
-Steering damper couldn't be adjusted, completely seized...
-On of the forks would get stuck in the compressed position (rebuilt)
-Quick shifter only working to upshift (autoblip stopped working)
-Becoming extremely difficult to start (new sprag, I am sure)
IN LESS THEN 3 MONTHS....and the bike is out of warranty.
Toronto, Canada
Maser is offline
post #2 of 23 (permalink) Old 08-29-2018, 11:36 AM
Allworld's Avatar
Seems like a lot of items for such low miles/kms. What is/was the issue with the turn signal and rear brake? My rear brake was not working well, problem solved by bleeding it and has been fine ever since.
Is the auto blip available in all modes or just sport and custom?
Bikes:
2015 Triumph Street Triple R
Allworld is online now
post #3 of 23 (permalink) Old 08-29-2018, 12:41 PM Thread Starter
Maser's Avatar
The turn signal is a common issue with all the models that use that time of turn signal; I know my dealer has replaced dozens of these units. Since new, I have replaced the left rear turn signal 3 times and the right side twice.
The rear brake had a leaking gasket causing the brake to lose pressure. When it comes to the quick sifter, the Dragster comes with quick shifter up and down from factory. The down part stopped working a month ago.
Toronto, Canada
Maser is offline
post #4 of 23 (permalink) Old 08-29-2018, 02:21 PM
Allworld's Avatar
I feel for your frustration. I am waiting on a fuel tank myself, and I know of at least one other person is as well.
Bikes:
post #5 of 23 (permalink) Old 08-29-2018, 02:23 PM Thread Starter
Maser's Avatar
I friend of mine is waiting for a sprag-clutch, it will be 3 months...winter will be here before it arrives.
Toronto, Canada
Maser is offline
post #6 of 23 (permalink) Old 08-29-2018, 04:38 PM
GeorgeO's Avatar
The Quickshifter downshift only works in Sports mode.
GeorgeO is offline
post #7 of 23 (permalink) Old 08-29-2018, 04:38 PM Thread Starter
Maser's Avatar
It is in sports mode...I was riding the bike home when out of the blue stopped working.
Toronto, Canada
Maser is offline
post #8 of 23 (permalink) Old 08-29-2018, 11:55 PM
GeorgeO's Avatar
So same happened on mine once - in the end it was the alignment of the shift rod with the strain sensor in it that i had to tweak to get it working. (i stripped the rod, cleaned, re-assembled and tightened everything, making sure alignment between the gear lever mounting point below and the upper gearshaft attachment point was in line (by moving the upper gearshaft pivot bracket inwards or outwards you effect the alignment).
GeorgeO is offline
post #9 of 23 (permalink) Old 08-30-2018, 04:08 AM
Bruce Taylor's Avatar
You certainly appear to have far more problems with obtaining parts on the other side of the pond, than we do in the UK.
It was necessary to replace six sprag-clutch's on the two F3's that I owned which was over a four year period and the parts were made available within days.
Now riding the 2018 DragsterRR Euro4 model, covered over 4000 miles and the revised sprag clutch system is working perfectly.
Bruce Taylor is offline
post #10 of 23 (permalink) Old 08-30-2018, 06:05 AM Thread Starter
Maser's Avatar
I will try that and see if I can get it working, thank you
Toronto, Canada
Maser is offline
