Oil Light - MVAgusta.net
 2Likes
  • 4 Post By silentservice703
post #1 of 7 (permalink) Old 05-24-2018, 04:06 PM Thread Starter
craigzx9's Avatar
Oil Light
Hi I have had numerous problems with my 2016 Dragster RR from the day I purchased it. but now whilst on tour in Spain the oil light came on, I checked and topped up the oil but is still on. I have replaced the oil sensor switch but no difference. if you check the switch there is polarity from the connector and the outer body and the polarity cuts out when you manually operate the switch, but when fitted there is polarity between the connector and the switch body, indicating there is not enough oil pressure to operate the switch, I have also checked and changed the oil. Can anybody please shed any light on this problem.
Many thanks
Craig
craigzx9 is offline
post #2 of 7 (permalink) Old 05-24-2018, 04:28 PM
Perhaps you actually have an oil pressure issue.....
Teeps, Teeps, airjawed and 1 others like this.
post #3 of 7 (permalink) Old 05-24-2018, 05:11 PM Thread Starter
craigzx9's Avatar
Is this a dealer job. ???
craigzx9 is offline
post #4 of 7 (permalink) Old 05-24-2018, 05:35 PM
Allworld's Avatar
There is a spring holding the filter cartridge in place, is that spring in correctly?
also are you using the the correct oil weight?
Bikes:
2015 Triumph Street Triple R
Allworld is offline
post #5 of 7 (permalink) Old 05-24-2018, 05:53 PM Thread Starter
craigzx9's Avatar
Hi the oil is all correct, and I have not changed the filter, is the spring holding that in?
craigzx9 is offline
post #6 of 7 (permalink) Old 05-24-2018, 07:26 PM
Allworld's Avatar
The spring does not hold the cartridge in, the spring sits on the underside of the cartridge, it keeps it tight and pushed up.... I'm not that technical so I can't explain the entire purpose but I do know it is important.
Bikes:
Allworld is offline
post #7 of 7 (permalink) Old 05-24-2018, 08:30 PM
you are certain it is not an electrical connection issue?
DO NOT operate the engine until you confirm oil pressure. Can you get an oil pressure gauge (screw it into the oil pressure sensor hole). Crank the engine with coils unplugged and check for at least some pressure.
Pressure relief valve stuck open? Not common, but someone else had one stuck closed....so I guess it's possible.
On the other hand, if you have been riding for a while with the oil light on, and the engine has not begun the death knock of rod bearing failure yet....then you probably have an electrical fault. Low enough oil pressure to turn on the light results in engine rod failure in a very short order.
