Rough gearing / RPM and gear changes - MVAgusta.net
post #1 of 7 (permalink) Old 04-27-2018, 06:23 AM Thread Starter
ngiunt01's Avatar
Hi Guys and Girls,
I have a new Brutale 800. Just breaking it in. I’ve noticed that when shifting from 1st to 2nd it’s tougher than the other gear shifts. Lower the. 5000Rpm and it’s better. Is this normal? Does anyone else experience this?
On that note, what RPM are people changing gears at generally. Eg. 1st 5000rmp, 2nd ?rpm etc?
Thanks in advance.
Cheers,
Nick
ngiunt01 is offline
post #2 of 7 (permalink) Old 04-27-2018, 06:28 AM
Wildfire's Avatar
Are you using the Quickshifter? If you are, remember it's a quickshifter, not an auto-gearbox. They work better at higher rpm, withbigger throttle openings,
Gearboxes do need bedding / breaking in. After the first hundred miles it will get easier.
Wildfire is offline
post #3 of 7 (permalink) Old 04-27-2018, 06:46 AM
Black_Gold_Saw's Avatar
I know exactly what you mean.
First 1000 miles I also felt that, but now roughly 2000 miles it buttersmooth. Even from 1st to 2nd gear. Although you need to really push lever up and not softly otherwise it will hit neutral.
Just do this for every gear. My tip: The harder you kick the lever the smoother.
Inbetween 4th/5th is a false neutral aswell. Just so you know.
"Mileena"
Black_Gold_Saw is online now
post #4 of 7 (permalink) Old 04-27-2018, 07:01 AM
Bruce Taylor's Avatar
Very rarely if ever do I use the quickshifter between 1st and 2nd. On occasions, it will hit false neutral between 5th and 6th. Do you have the autoblipper on your bike?
Agree, the more miles on the clock the smoother it becomes.
Bruce Taylor is offline
post #5 of 7 (permalink) Old 04-27-2018, 07:01 AM Thread Starter
ngiunt01's Avatar
Thanks Wildfire - no I’m not using quick shift. Not whilst breaking in and I’m going to reserve it more so for riding fast.
So a clunk from 1st to 2nd is normal, until it’s hroken in at least?
Cheers.
ngiunt01 is offline
post #6 of 7 (permalink) Old 04-27-2018, 07:03 AM Thread Starter
ngiunt01's Avatar
Thanks Black_Gold_Saw - was it like a clunk between 1st and 2nd? It’s not terrible but more like Harley gearing. The rest of the gears are butter smooth.
Cheers.
ngiunt01 is offline
post #7 of 7 (permalink) Old 04-27-2018, 07:05 AM Thread Starter
ngiunt01's Avatar
Hi Bruce, I do have an autobliper. I’m not using it whilst breaking it in.
ngiunt01 is offline
