EAS quickshifter issue - MVAgusta.net
post #1 of 5 (permalink) Old 01-10-2018, 08:02 AM Thread Starter
Any ideas/experiences on why a quickshifter wont blip up but blips down fine?
In sport mode so it should go both ways, in fact, historically it has.
(my2015 brutale dragster 800 rr)
Digital is offline
post #2 of 5 (permalink) Old 01-10-2018, 08:16 AM
There should not be a blip on the upshift quick shift
Mschwechter is offline
post #3 of 5 (permalink) Old 01-10-2018, 08:19 AM Thread Starter
not really sure what you mean...
maybe if I reword the issue to , my quickshifter downshifts correctly but doesnt upshift. any ideas why this might be ?
Digital is offline
post #4 of 5 (permalink) Old 01-10-2018, 10:59 AM
The quickshifter is dodgy, the slightest bit of moisture will make it go haywire. There are many threads that address solutions to this issue.
You can either get a 3rd party better quality one, replace this one with a working one (under warranty if you still have), or you could wait for you current one to dry out and get to a working state, then use some silicone to waterproof it a bit more.
One thing to be sure of tho, make sure that the quickshift function is actually on. The symptoms you described can be easily mistaken. When the QS function is off and you dont realise, you are actually clutchless shifting down, cos you let off the throttle just before you down shift. This gives a false impression that the QS is working. But when you go to QS up, you dont need to let off the gas, so it doesnt work. As you may or may not know, because there is still load on the gears, they will not clutchless shift this way.
Have a quick check in the settings
Kag
Kag
Kageira is offline
post #5 of 5 (permalink) Old 01-10-2018, 11:12 AM
Gero HH's Avatar
welcome to the club.. I had 3 QS replaced I'm on my 4th now... (same Part No as for the Dragster RR 800) luckerly it was at warranty, the next one will be not!! (just 1 month left of warranty ) My choice is the QS from HM !!
HM Quickshifter ? Product Categories ? HM Quickshifters
Greetings from Hamburg
Gero
______________________
2016 Turismo Veloce 800 Lusso
Gero HH is offline
