HELP! Does anyone know how to remove Dragster's front screen? - MVAgusta.net
post #1 of 4 (permalink) Old 06-24-2016, 12:56 PM Thread Starter
and replace with this?
I only managed to remove the front metal triangle bit, and two rubber plugs behind it, seems like the instrument cluster need to come off in order to remove the screen.
Please help!
E_D_I_S_O_N is offline
post #2 of 4 (permalink) Old 06-24-2016, 01:12 PM
Jogort's Avatar
Have a look here, might give ya an idea. Never had to take it of myself.
http://shop.startwintrading.com/en/p...ng-assembly-96
Current steed - MY16 Dragster RR
Previous Bike - 2008 Triumph Street Triple
Scottish and living it up in South East Spain
Jogort is offline
post #3 of 4 (permalink) Old 06-24-2016, 01:17 PM
Jogort's Avatar
Also, the workshop manual only shows removal of the Brutale screen which is different to the Dragster. Other than that it shows removing the dash, which seems simple enough anyway.
Jogort is offline
post #4 of 4 (permalink) Old 06-25-2016, 09:27 AM
Arcimboldo's Avatar
Lightbulb
Originally Posted by Jogort View Post
...the Brutale screen which is different to the Dragster. Other than that it shows removing the dash, which seems simple enough anyway.
Had a look at the steal^H^H^Hdealer
Dragster screen doesn't look that different from the vanilla Brutale.
Remove from the front
the only screw holding the dash panel.
Without an articulated screwdriver you might have to remove the headlight housing before.
Screw removed [behind the dash cable]
To remove dash;
pull sort of hard 'cause the pegs on the panel are a tight fit
in the two silentblocks on top
Unplug dash.
Now you can get at the screws holding the screen
HTH
Dragster 800
Arcimboldo is offline
