F3 800 Headlight bulb wiring, Melted - MVAgusta.net
post #1 of 4 (permalink) Old 05-16-2019, 03:24 PM Thread Starter
It seems my Headlight bulb connector melted to the bulb, Highbeam indicator is stuck on and the headlight does not work..
Has anyone had this happen? If so how did you fix it? It seems the connector only comes on a complete bike harness.
brent98rt is offline
post #2 of 4 (permalink) Old 05-16-2019, 05:59 PM
You had a poor or corroded connection which created resistance which resulted in heat and melted plastic.
You can fix the connector. This guy sells everything you need:
Motorcycle Terminals, Connectors, and Wiring Accessories
post #3 of 4 (permalink) Old 05-17-2019, 06:15 PM Thread Starter
Thanks for the link.
post #4 of 4 (permalink) Old 06-13-2019, 11:43 AM
Moriwaki's Avatar
Another source I used in the past:
https://easternbeaver.com/Main/Elec_...onnectors.html
2013 F3 800 (track only)
The older you get, the faster you was
Moriwaki is offline
