Oh the surprises - MVAgusta.net
 2Likes
  • 1 Post By Pulse
  • 1 Post By jdgun
post #1 of 8 (permalink) Old 09-10-2018, 09:36 PM Thread Starter
Oh the surprises
Not sure how many have ventured into the used F3 realm, but i was pretty sure the bike i bought was never tore apart for whatever reasons (according to the dealer).... Well judging by the amount of zipties used for this and that to hold brakelines together and other things, in the wiring and routing of whatnot, there be A LOT of zipties..
Did find a very light oil weapage from the valve cover, so guessing that might be why she was tore down before.. hoping to get a vin check from another dealer and see what maintenance work was done.
Anyone else have a similiar issue?
jdgun is offline
post #2 of 8 (permalink) Old 09-11-2018, 12:34 AM
Pulse's Avatar
Light oil leakages, especially on the left front of the valve cover, is fairly common on F3s. Its an easy fix. Loads of examples on here
jdgun likes this.
Pulse is offline
post #3 of 8 (permalink) Old 09-11-2018, 06:10 AM
Wildfire's Avatar
Doesn't sound right with the ties. I've had mine apart and I found very few zip ties, except those that had been out on by a dealer mechanic. There was a lot of the rubber elastic things though.
"Way out running!"
F3 675 - 2013
Wildfire is offline
post #4 of 8 (permalink) Old 09-11-2018, 06:18 AM
PTsalas's Avatar
No zip ties on mine when I took it apart to replace the valve cover seal (also had an oil leak on the front left).
MV like using rubber ties.
PTsalas is offline
post #5 of 8 (permalink) Old 09-11-2018, 06:39 PM
A little RTV to help out the valve cover gasket maybe?
Strider78rr is offline
post #6 of 8 (permalink) Old 09-12-2018, 09:56 AM Thread Starter
What I am thinking is they had the bike apart for the valve cover leak, and used zipties when putting it back together versus the rubber ties. will get back in there this winter and fix the leak, not much time left for riding this year, so not going to hassle with it.
silentservice703 likes this.
jdgun is offline
post #7 of 8 (permalink) Old 09-13-2018, 11:48 AM
airjawed's Avatar
There are what appears to be factory zip ties and rubber straps throughout my bike. Doesn't really look like a shop job in my case. Do you have pictures?
2014 MV Agusta F3 800 ABS
airjawed is offline
post #8 of 8 (permalink) Old 09-13-2018, 02:44 PM Thread Starter
Sorry, already cut quite a few off the bike when I pulled the brakeline from the ABS.the only ones I could possibly see are the odd ones that were on the fabric cover over the brakelines by the module.
many of the places where they were located would definitely be rubber straps.
jdgun is offline
