2018 new crankcases / Covers - MVAgusta.net
post #1 of 5 (permalink) Old 12-27-2017, 09:38 AM Thread Starter
PTsalas's Avatar
I see the 2018 MV F3 has a new clutch cover that extends a lot further back leading me to believe that the 2018 model has a different rear crankcase to prior models.
Anybody with some inside info on the changes?
I see the ignition side has a full plastic cover covering the entire LHS of the motor, is it possible the clutch side is also a plastic cover?
If it is a plastic cover, what would the primary purpose be? Noise reduction?
PTsalas is offline
post #2 of 5 (permalink) Old 12-27-2017, 09:42 AM Thread Starter
PTsalas's Avatar
I see they also plugged the top opening on the swingarm, you can no longer see the chain running through the swingarm. I take it that would be for noise also?
PTsalas is offline
post #3 of 5 (permalink) Old 12-27-2017, 12:52 PM
Any pictures of said details?
jdgun is online now
post #4 of 5 (permalink) Old 12-28-2017, 07:15 AM Thread Starter
PTsalas's Avatar
PTsalas is offline
post #5 of 5 (permalink) Old 12-28-2017, 10:30 AM
So a plastic engine cover on the Stator side, and is the clutch cover actually made of plastic instead of aluminum?
odd they closed off the swingarm.
I do like how they moved the rear brake reservoir, going to look into buying the mounting bracket (or make my own) to move mine there.. cleaner for sure.
jdgun is online now
