Tank wiring mod - MVAgusta.net
post #1 of 7 (permalink) Old 12-13-2017, 05:36 AM Thread Starter
kevjayney's Avatar
Tank wiring mod
I was finding it very hard to connect the fuel pump wiring under the tank every time I fitted the tank after removal, so I thought I would share what ive done to make it easier for myself.
There are various other connectors out there to choose from, I just like these as they are waterproof.
I am not sure if all the wiring is the same for other models as this is for F3 675.
This is just a guide on how I did it, there are many other ways.
Using the correct manual for your bike, remove the tank, remove the battery leads and measure where to cut the wiring to fit your new connector, which will be accessible once fitted.
Note :- One my model there are 2 blue wires, they are different thickness wires, so take note which is which.
Cut and prep the wire ends to suit your connector.
Once that is done, push the original connector onto the fuel pump under the tank and the new connector end will be hanging down below the tank.
Refit the battery leads and tank as per manual with your new wiring connector, start up bike and check everything.
Lang mae yer lums reek
2001 F4 750 1+1
2012 F3 675
kevjayney is offline
post #2 of 7 (permalink) Old 12-13-2017, 05:40 AM Thread Starter
kevjayney's Avatar
wiring
2001 F4 750 1+1
2012 F3 675
post #3 of 7 (permalink) Old 12-13-2017, 05:44 AM Thread Starter
kevjayney's Avatar
wiring 3
2001 F4 750 1+1
2012 F3 675
post #4 of 7 (permalink) Old 12-13-2017, 06:12 AM Thread Starter
kevjayney's Avatar
wiring 4
2001 F4 750 1+1
2012 F3 675
post #5 of 7 (permalink) Old 12-13-2017, 06:14 AM Thread Starter
kevjayney's Avatar
wiring 5
2001 F4 750 1+1
2012 F3 675
post #6 of 7 (permalink) Old 12-13-2017, 06:18 AM Thread Starter
kevjayney's Avatar
wiring 6
2001 F4 750 1+1
2012 F3 675
post #7 of 7 (permalink) Old 12-13-2017, 07:26 AM
Nice work. Looks like it will be nicely hidden behind the side panel...
