Vibrate ? - MVAgusta.net
  • 2 Post By Deano
post #1 of 7 (permalink) Old 07-31-2017, 09:19 PM Thread Starter
AJ1
AJ1's Avatar
Vibrate ?
I've noticed the engine vibration starting from mid rpm
Normal?
AJ1 is offline
post #2 of 7 (permalink) Old 08-01-2017, 01:51 AM
Deano's Avatar
What bike? What year? What revs?
Deano
Kageira and Kageira like this.
Deano is offline
post #3 of 7 (permalink) Old 08-01-2017, 08:43 PM Thread Starter
AJ1
AJ1's Avatar
F3 800, 2015, 6-7k
AJ1 is offline
post #4 of 7 (permalink) Old 08-02-2017, 01:32 AM
Deano's Avatar
AJ1,
Can't comment on your specific model but my 2009 1078 vibrates (felt through the bars) at about 5000/6000rpm. This is at our legal 100km/hr limit and a bit of a pain in the arse. Not many bikes around, especially one's that I've owned, that don't have a vibration period that is annoying to the rider at some usually used speed. So on that count I'd say it's pretty normal. Having it balanced would be an expensive fix so most of us live with it.
However I changed bars to Rizomas and that probably made the vibes worse. So I added weights up inside the bars that I machined from s.s. Probably were'nt more than 150g each but it was an improvement. Then when I added bar end mirrors it really improved things. These were a cheap Chinese copy of CRG's but had a bit of weight and you could actually see out of them so no vibration, or minimal. Heavier than the std. bar ends. Mirrors were crap and when one shit itself I got another set. However these are much lighter and vibration again.
Latest fix was to pour about 250g of shotgun pellets I had in a jar down the bars. Big improvement. Next I'll track down some more and fill the bars.
So there are a few solutions available some cost more, others take more time and fucking around. Or just ride with it.
Deano
Deano is offline
post #5 of 7 (permalink) Old 08-02-2017, 02:40 AM Thread Starter
AJ1
AJ1's Avatar
Deano,
Thanks...worst case is the ducati, the F3 is not that bad
- Motorcycle Art -
AJ1 is offline
post #6 of 7 (permalink) Old 08-02-2017, 04:42 AM
Deano, maybe get the crucible one would use to cast projectiles or fishing sinkers (if you do make your own) and heat up some lead before pouring it into the bars?
Nice and heavy eh..?
Currently in the shed...
2007 F4 312R Black / White / Red.
2012 HD FXDWG 103 Blue Flames
2013 Ducati Diavel Very Black Metallic
1981 Triumph T140 Bonneville Maroon / Cream.
1973 Yamaha CT3 175 chook chaser
Adelaide...Sarf-A-Straylia
albymangled is offline
post #7 of 7 (permalink) Old 08-02-2017, 06:50 AM
Deano's Avatar
albymangled,
Yeah used to cast my own mini balls when I shot black powder. This was going to be my next try after the shot. But once you fill it full of molten lead you're stuck with it, whether it works or not. I think the shot will be the best as there's thousands moving against each other and hopefully cancelling out the worst of the vibration.
Deano
Deano is offline
