Battery Charger - Where do you plug it in? - MVAgusta.net
post #1 of 7 (permalink) Old 03-12-2017, 05:44 AM Thread Starter
twosmoke's Avatar
Tried to start my F3 800 RC yesterday, and whilst it has enough charge to turnover, it's a bit sluggish so battery needs charging.
Bike was supplied with a charger (with a two pin plug at one end - not very helpful for UK use, so have to get a converter plug for that). Nothing mentioned in the manual and no instructions in the charger box. Checked under the seat and there are two sealed blocks. One with 'D' marked on the lead, the other with 'L'. Can't see anywhere, where the lead should be plugged in.
Can anyone let me know where the connector is please?
Cheers.
twosmoke is offline
post #2 of 7 (permalink) Old 03-12-2017, 08:49 AM
Black_Gold_Saw's Avatar
Well there should be a battery charger connector under the passenger seat. There are 2 cables very visible but 1 is tugged away underneath the frametube(atleast mine was)with red/blue wiring.
I've removed my fairings while adding a tail tidy and pulled the cables more out of the fairings. As you can see the charger cable is still super short. So take a good look underneath the frametubing
Black_Gold_Saw is offline
post #3 of 7 (permalink) Old 03-13-2017, 08:41 AM Thread Starter
twosmoke's Avatar
Can't see any plug like that under my seat (see pic below)...
twosmoke is offline
post #4 of 7 (permalink) Old 03-13-2017, 09:13 AM
It's right there. You should remove the rubber protective cap. That should be the battery chargers connector cable.
Remove as in, pull it off not cut or slice it open.
The Following User Says Thank You to Black_Gold_Saw For This Useful Post:
post #5 of 7 (permalink) Old 03-13-2017, 05:18 PM
Wildfire's Avatar
It's the one with the Blue and Red Wire if I'm not mistaken. Take the rubber cap off and you will see one end of a superseal connector. Just use an adapter on the battery tender and it will be fine.
A word of warning, trying to start with a low battery is a sure fire way to kill your sprag clutch. If the battery isn't strong, get it on charge and don't keep trying to turn it over.
Wildfire is offline
post #6 of 7 (permalink) Old 03-14-2017, 04:22 AM Thread Starter
twosmoke's Avatar
Black Gold,
All sorted now.
Thanks for posting up the snaps and explaining where MV hid the connector.
Wildfire,
Thanks for the advice.
Yes, I have read about the sprag clutch issues and I am very careful when starting. I realised it needed charging immediately and didn't labour it.
twosmoke is offline
post #7 of 7 (permalink) Old 03-14-2017, 04:58 AM
Black Gold,
All sorted now.
Wildfire,
Depending on how you ride of the street/city the dynamo in the bike start making electricity at 5.000RPM. So if u ride mostly below these RPM's I would suggest to charge the battery every weekend of once every 2 weeks. (In mind that u still got factory OEM battery in it)
