F3 (675) some fork dimensions? - MVAgusta.net
post #1 of 9 (permalink) Old 09-18-2016, 01:22 AM Thread Starter
Hi All,
I noticed in another thread that the 675 has 50mm fork tubes. IF someone could tell me the fork center to center distance and the offset I would greatly appreciate it.
Offset looks like this.
cheers
maelstrom is offline
post #2 of 9 (permalink) Old 09-18-2016, 11:45 AM
PTsalas's Avatar
F3 has 43mm lower fork tubes I think. Not sure about the offset.
PTsalas is offline
post #3 of 9 (permalink) Old 09-19-2016, 12:44 AM Thread Starter
Thanks for the reply PT. The stanchion diameter is not important to me because this project is made of various bits and pieces. From what I know so far I think the F3/675 top clamp might be a perfect fit if it has a 210mm center to center and 30mm offset. It is a bit difficult to verify this of course and hence my post.
cheers
Blair
post #4 of 9 (permalink) Old 09-19-2016, 09:01 AM
Ducati23's Avatar
The upper tubes where the top clamp and clip-ons mount is in fact 50mm. I have a complete set of F3 triples on hand and could check the numbers for you.
I can't remember what the stock offset or center to center distance is. I'll check tonight.
The top clamp might be a perfect fit for what?
D23
CCS/ASRA #19
'Yamaha R1 Superbike
MV F3RC
Zuma 125
Ducati23 is offline
post #5 of 9 (permalink) Old 09-19-2016, 09:15 AM
GREGOSTINI's Avatar
At a quick measure in the dark, with the torch held between my teeth, 30mm offset looks about right. Center to center is 205mm. 2012 675 F3.
GREGOSTINI is offline
The Following User Says Thank You to GREGOSTINI For This Useful Post:
post #6 of 9 (permalink) Old 09-19-2016, 09:26 AM Thread Starter
Thanks D23, it would be much appreciated by a fellow motorcyclist. At the risk of being branded a heretic, it is for my project Yamaha FZR400 that I am modelling on the R7. Well trying to. I live in Thailand so money is scarce and big bikes are both rare and hideously expensive. The forks and lower triple come from two different model of R1, so that I could keep the same geometry as original. I didn't want to use the hideous Yamaha top clamp with its stupid double nut, and I had no need of the ignition switch because I have an RFID unit. And finally to accommodate the MV/Ducati method of clamped nut I used a custom made titanium stem. So the big hope is that the MV part fits otherwise it is back to drawing the top triple.
cheers
post #7 of 9 (permalink) Old 09-19-2016, 10:32 AM Thread Starter
@Gregostini looks like you are right. Carpimoto answered a message I sent them with the same dimensions as you. Oh well
post #8 of 9 (permalink) Old 09-19-2016, 03:07 PM
Ducati23's Avatar
Center to center is 205mm - Offset is 30mm
D23
CCS/ASRA #19
MV F3RC
Zuma 125
Ducati23 is offline
post #9 of 9 (permalink) Old 09-19-2016, 08:35 PM Thread Starter
Thanks guys.
I also added it to my page for for fork info. If you are ever looking for dimensions for some reason it might be useful. http://litetek.co/Guide_USD_ForkDatabase.html
cheers
