DesignCorse EPROM tune - MVAgusta.net
post #1 of 3 (permalink) Old 01-29-2015, 10:15 AM Thread Starter
lgp0722's Avatar
Al,
I'm considering going with the EPROM tune on sale through your storefront. I just had a few questions for you...
Any issues or special programming needed for US-spec ECU's, being that you all are in the EU?
The lambda regulation and exhaust valve settings wouldn't apply to an 06 1000 S, correct?
Will any further tuning (tb balancing, CO2 adjustment, etc) be required after fitting of the tuned EPROM to make the bike run properly, or should it in theory be plug-and-play?
Do you have before/after dyno sheets or numbers for the 1000 S motor?
Lastly, my bike has a decat link pipe, but other than that is all stock. I have a nasty power flat spot at 4k-5k, but over that it picks up normally. I understand that without throwing it on a dyno you can't say for sure, but is that something that getting a tune for that setup through you would usually smooth out?
Thanks for your time!
lgp0722 is offline
post #2 of 3 (permalink) Old 01-30-2015, 05:41 AM
King of Carbon
DesignCorse's Avatar
PM sent with requested info.
Regards
Al
T: +44 (0) 1582 840 024
DesignCorse is offline
post #3 of 3 (permalink) Old 02-02-2015, 09:19 AM Thread Starter
lgp0722's Avatar
Thanks!
lgp0722 is offline
