Rainy Track Days? - MVAgusta.net
post #1 of 8 (permalink) Old 06-17-2015, 11:53 AM Thread Starter
TDUBB's Avatar
Rainy Track Days?
I'm going to MSRH this weekend for my first track day on my F3 and we have 80% chance of rain.
Any tips for rainy days?
Should I still run the same tire pressure? On my R1 I would run 29 rear 31 front.
TDUBB is offline
post #2 of 8 (permalink) Old 06-17-2015, 12:10 PM
Ian SAVS's Avatar
Send a message via Skype™ to Ian SAVS
Get a rain cover for your leathers.
What we've got here, is failure to communicate.
03 F4750SR
07 F41000R
Ian SAVS is offline
post #3 of 8 (permalink) Old 06-17-2015, 03:57 PM
Wet track will keep tire temps down...best check with tire supplier at track (if there is one) for recommendations.
Most street tires do a decent job on a wet track with pressures close to normal road riding. You'll be amazed how fast you can go in the wet.....
post #4 of 8 (permalink) Old 06-17-2015, 04:34 PM
Run wets
mgivogue is offline
post #5 of 8 (permalink) Old 06-17-2015, 05:43 PM
midget81's Avatar
Stay home
Terry
2011 F4
midget81 is offline
post #6 of 8 (permalink) Old 06-18-2015, 07:51 AM
ASM
ASM's Avatar
You need to be smooth for every input given to the motorcycle - no sudden input on throttle, brakes or steering. Reduce lean angle by moving your body off the bike more. Be open, relaxed and get with a coach...a wet track will teach you a ton...
Ciao, Andreas
ASM is offline
post #7 of 8 (permalink) Old 06-18-2015, 08:31 AM
GREGOSTINI's Avatar
Don't be tempted to drop your tire pressures excessively, it will allow the tread to close up and reduce the tires' capacity to disperse water. Best to stick with dry pressures, or close to, and ride conservatively.
GREGOSTINI is offline
post #8 of 8 (permalink) Old 06-18-2015, 09:13 PM Thread Starter
TDUBB's Avatar
Cool, thanks guys, higher pressure makes since. I'm not happy about having to run wet, but I do think it'll make me a better rider.
On a good note, Tropical storm Bill was not as bad on the coast as they predicted and rain chances have gone down from 80% to 60%. Hopefully I'll get some dry and wet time.
TDUBB is offline
