Gen 2 F4 on track - MVAgusta.net
post #1 of 17 (permalink) Old 05-28-2015, 03:00 PM Thread Starter
Gen 2 F4 on track
Is it just me or is this bike freakishly high compared to other track bikes???
mgivogue is offline
post #2 of 17 (permalink) Old 05-28-2015, 04:19 PM
The seat height, etc are similar to all the other liter bikes out there....so it must just be you?!?
Center of gravity, rider ergonomics, suspension sag, chassis geometry all combine to create the sensations you feel while sitting on and riding a bike.
post #3 of 17 (permalink) Old 05-29-2015, 03:36 AM Thread Starter
ummmm....stock setup, put on a 200/60 pirelli and i cannot touch both feet - even on tippy toes. Seat height is higher so not only a sensation. Also, at a track where i get my knee down on nearly every corner i am no longer able to do so except on a few corners...clearance (at least to me) is very high
That said, does anyone have experience in how far it is safe to drop the forks? Next trackday is time to start working on ride height/geometry and if anyone has experience that can pass on a decent baseline that i can start with it would same me time/effort when at the track.
mgivogue is offline
post #4 of 17 (permalink) Old 05-29-2015, 03:43 AM Thread Starter
just looked up seat heights:
F4 860mm
ZX10R 813mm
Ducati 1198 820mm
Ducati Panigale 825mm
Aprilia RSV4 810mm
5cm is a lot for short buggers like me! BTW, sag/comp/rebound setup as per maint manual or normal starting points on-track - need to work on base setup (geometry/height, work on preload/compression in front to get full fork travel and watch the tires for wear patterns to adjust the rebound)
mgivogue is offline
post #5 of 17 (permalink) Old 06-01-2015, 02:44 PM Thread Starter
Wtf!
Went to drop the front forks 2 lines which is a "good starting point" as per dream team(checked all clearances and good)...found that the right fork was already dropped half a line compared to the left. I'm going to assume it is from the accident before I bought it but I see no other movement.
Donsy, you mentioned 1 line = 4mm at the rear in another thread...can you confirm? I'm going to drop the rear the equivalent of 1 line to lower the bike in general and quicken the steering at same time (again- dream team)
mgivogue is offline
post #6 of 17 (permalink) Old 06-01-2015, 07:57 PM
Lightbulb
Originally Posted by mgivogue View Post
Wtf!
You should measure it yourself and keep notes.
post #7 of 17 (permalink) Old 06-15-2015, 03:30 PM Thread Starter
Ok - feedback from 2 days testing...if anyone is interested❓❓❓
2 setups tried
1. Own star wheels with Michelin power cup tires (190/55 rear)
2. BST wheels with Bridgestone v02 slicks (120/600 front and 200/655 rear)
Start of test - recommend track settings as per manual, front dropped by 2 lines on forks and rear dropped by 5mm and 29mm sag front and rear
End of test - same geometry, 2.5 turns less front preload, 4 clicks less front compression.
Results:
Star wheels- steering a bit slow still, might drop front 1 more line
BST wheels - no more geometry changes needed.
Both - MUCH more at ease (no longer feel like a midget on a normal sized bike, easier to judge track position and get knee down similar to my full race prepared Daytona 675). Clearance good - room to drop anoth line or more at front and 4-5mm lower in back before need to worry. Fork travel - 1.5cm from bottoming out - another 2-4 clicks less compression and 0.5-1 turn less preload??? Rear pretty good (tire wear only needed 0.05 bar more pressure on Michelin rear as showing signs of overheating) but it was obviously heating up at end of 25 minute runs even with exhaust wrapped. Times within 2 seconds of Daytona at very technical track where power is nearly meaningless and handling/weight everything
Conclusion - going in right direction. Front needs more tuning and replace springs (near minimum preload) and lighter fork oil...rear needs new shock.
Back testing in 2 days ��
mgivogue is offline
post #8 of 17 (permalink) Old 06-15-2015, 05:43 PM
Those 600 and 655 aspect ratio tires must make the bike VERY tall...
(Great cornering clearence though, I'm sure...)
post #9 of 17 (permalink) Old 06-16-2015, 12:51 AM Thread Starter
They do. That's why I dropped the rear a bit as well
mgivogue is offline
post #10 of 17 (permalink) Old 06-16-2015, 04:44 AM
