Braking Wave Rotors(Ducati 748R/998R/KTM) - $600 - MVAgusta.net
post #1 of 1 (permalink) Old 05-03-2011, 07:37 PM Thread Starter
Soheil's Avatar
A set of brand new Braking "Wave" SBK front brake rotors for Ducati 01 748R in 320mm with 15mm offsets. It will not work on the standard 748/916/996/998, unless you have the 998R version!
Check for the earlier 748R specs to see if they will fit! These rotors are discontinued and no longer available. You can also upgrade your 748/916/996/998 Showa front-ends with either Ohlins/Showa forks with radial bottoms(999/1098 forks) and you will for sure have to use rotors with the 15mm offsets, otherwise you have to add 5mm spacers to the existing 10mm stock units(Not the best option at all).
Fantastic braking and definitely beautiful, they weigh so much less than the stock units. They will also fit KTM larger bikes which use 6 mounting bolts pattern and are mated with radial calipers. Please do your own research about the KTM application. The rotors are new in box and ready to be shipped. The carrier is billet and anodozied in Satin Black.
They have a great thermal transfer rate and many use them on the track as well as on the street. As I mentioned, they are almost impossible to find now. Made in ITALY. The retail was over $350 each. I'm selling them both for $600 shipped within the U.S lower 48 States. Price is firm. Please call me if serious and interested: (408) 431- 7707
Be gracious and thankful! You are alive!
Soheil is offline
