CNC frame caps & bar ends - MVAgusta.net
post #1 of 6 (permalink) Old 06-26-2018, 11:47 AM Thread Starter
bbycakes's Avatar
Has anyone bought them and tried installing it themselves? I’m having a hard time installing 2 caps. They just seem a bit off.
As for the bar ends, there’s some sort of weights? Inside the bar. You can also see they kinda screw in and the CNC don’t. I’ve never seen this before. Any suggestions? Thanks ✌️
bbycakes is offline
post #2 of 6 (permalink) Old 06-26-2018, 09:37 PM
The bar ends are like expansion fasteners.....like a big well nut. Slide it in and tighten up the screw....the rubber bush will compress and swell to hold the inside of the bar.
No help on the frame plugs, sorry.
post #3 of 6 (permalink) Old 06-26-2018, 11:25 PM
TheycallmeJeff's Avatar
Hopefully there are a couple of different size rubbers with your bar ends. I had to shave the rubbers a bit with mine so they would fit in side my bars. As long as you can get the nut inside you should be able to work something out.
TheycallmeJeff is offline
post #4 of 6 (permalink) Old 06-27-2018, 09:27 PM
haupti's Avatar
Yeah screw that Bar End in a bit, but do not tight it, and then work that thing out.
No help on this frame plugs from me, those things add only unnecessary weight, and are obsolete in my eyes.
haupti is offline
post #5 of 6 (permalink) Old 06-29-2018, 11:24 AM Thread Starter
bbycakes's Avatar
Thanks for the input guys but I just decided to return them. They didn’t have much weight in them. I got them mostly for the added weight and looks of course. My bars are very vibey so unfortunately I have no choice but to have weighted bar ends
bbycakes is offline
post #6 of 6 (permalink) Old 06-29-2018, 02:40 PM
I have Motovations weighted bar ends with the recess for CRG LaneSplitter mirrors. That and gel grips took care of my vibes.
You can also look into a "Bar Snake". They work well.
