Turismo Veloce, Rivale, Stradale - How do you load and fix a bike in a trailer? - MVAgusta.net
 5Likes
  • 4 Post By Arcimboldo
  • 5 Post By Fastspy
post #1 of 8 (permalink) Old 02-11-2018, 09:40 AM Thread Starter
MarcSilverTriple's Avatar
Hi all,
I had to use the trailer to get the bike to the dealer and to get it back. Usually, on my previous bikes, on the front, I was fixing the bike either from the inferior T, either by the handlebar with some adapted straps.
On the Turismo Veloce, none of this is possible : on the inferior T there is two metallic part preventing dirt to go thru, and as a result, straps won't go there, and if they go there, they'll be quickly damaged. On the handlebar it's not possible as well, due to the handguards preventing the use of the handlebar straps. Only way was to use pass the straps thru the frame inferior main tube.
I suspect similar difficulties may be present due to hand guards on Dragster, and for Rivale and Stradale due to the profile of the fairings.
Looking for your feedback for next time I'll have to use the trailer.
Thanks.
Marc,
Turismo Veloce in France
Ride with us in Vosges :
MarcSilverTriple is offline
post #2 of 8 (permalink) Old 02-11-2018, 10:03 AM
Use soft nylon loops through any available frame member...or around fork leg.
post #3 of 8 (permalink) Old 02-11-2018, 11:17 AM
Arcimboldo's Avatar
Thumbs up Why load a bike on a trailer?
You are doing it wrong .
Maybe your bike like my TV and my Stradale came with two wheels and engine in between.
On my bikes I sit on top, grab the handlebars with my hands. Rather easy, no need for any kind of strap. And let the engine and wheels do their own job.
Got no car and natürlich no trailer.
Had a few MVs and even other brands of cycles for years and lots of lots of kilometers (a midge less in miles, ‘twas in the US). Never had to use a trailer!
Case bike engine or wheels can’t or won’t do their trick.
I carry some very small flat handy items in my pockets: mobile phone, bank card and warranty card for the balky MV.
Hence obvious help and answer:
Sit on your bike and ride it.
Forget about trailer, straps and other senile doddering old age props or implements.
Dragster 800
Arcimboldo is offline
post #4 of 8 (permalink) Old 02-11-2018, 12:59 PM Thread Starter
When the f* pressure switch and the slave cylinders are dead, riding it is not really an option (well, technically, the combination of both faulty parts makes it impossible to do the trick). Further I had to get back from the dealer. And then to get to the dealer to get the bike back. For any of the possible options, you get two vehicles one way, one vehicle the other way (and this two times). And for the assistance, their tool is a map, and they don't have a clue about what the hell a MV Agusta dealer is. So, one vehicle, a trailer and a single driver is the optimal way to make it. Obviously I could have arranged with my dealer to get the bike at home. But doing this way, I'm just saving this option for when I actually need it...
In any case, still better to know how to fix the bike to the trailer. Just because this simple knowledge will save you additional damage while some f* assistance transporter is doing it wrong, because you'll be able to highlight him :-D
Marc,
post #5 of 8 (permalink) Old 02-11-2018, 02:08 PM
Arcimboldo's Avatar
Wink only solutions
Originally Posted by MarcSilverTriple View Post
...So, one vehicle, a trailer and a single driver is the optimal way to make it. ...
BTDT
'Xcept on the Stradale faulty pressure switch means no way to start the engine.
Starter button dead.
Phone the dealer, it's an obvious warranty claim.
With a Stradale, a short slope and bump start.
A TV starts with or without the clutch,
good thing because bump starting a TV doesn't work,
then I'll would kick the gears into submission.
Get to the stea¨H¨H¨Hdealer, borrow his TVL while he hunts for the faulty part
and I ride on my merry way.
Not optimal mebbe
but simpler than senile gesticulations with trailer or straps.
Saves me the car I haven't. 'Cause without a car or a truck a trailer isn't a bright idea.
Dragster 800
post #6 of 8 (permalink) Old 02-11-2018, 02:41 PM Thread Starter
Not optimal mebbe
Where I live it would not be realistic to rely on a bike the whole year. Therefore, I have a car.
Then the trailer : it's a general purpose stuff generally dedicated to move stuff times to times to waste recycling center of the area... and sometimes to move a bike to the dealer or a to a track day session without any legal stuff on it (let's be clear - NOT the TV).
And this trailer is also something my friends borrow time to time to move their wrecked or non functional bike into a garage where someone will start to make some magic about it so it is brought back to life... So in fine, it's fine to have a trailer and a car.
Conclusion : if you don't have a car and a trailer, try to have one friend who have those just in case.
Marc,
post #7 of 8 (permalink) Old 02-12-2018, 01:13 PM
noggin's Avatar
Just a suggestion,
Front wheel chock anchored/bolted to the trailer and wheel strapped to chock, ratchet straps through the rear frame anchored to the trailer.
Turismo Veloce
Brutale 920
noggin is offline
post #8 of 8 (permalink) Old 03-26-2018, 09:30 PM
Fastspy's Avatar
A little late to this thread but here is how I transported my TVL 2200 miles.
I use a front wheel chock made by Condor called the pit-stop. They claim only two straps are necessary to secure the bike.
I ran a ratchet strap off each side of the frame forward and also another off each rear passenger footpeg mounts. Probably overkill for the chock but insurance in my mind. The straps I wrapped around the frame have a sheepskin cover to eliminate any abrasion.
Straps were not tight in the pic since this was prior to departure.
Fastspy is offline
The Following User Says Thank You to Fastspy For This Useful Post:
