Problem with all helmets help please - MVAgusta.net
 2Likes
post #1 of 26 (permalink) Old 07-16-2017, 01:51 AM Thread Starter
uwiik's Avatar
As I grow older with three kids and couple millions of business capital debts I value my life more and more and I began re evaluating my safety gears. Just last week I heard a horror story from a senior rider, he told me that he witnessed too many lost lives due to one size too big helmet, saying that wearing a high end helmet that is one size too big is as unsafe as wearing cheap Chinese helmet. I became paranoid and re evaluated my helmets with proper fitting references from the internet and I just found out that I have been riding with (I assume) wrongly fitted helmets since 1994...Due to lack of informations (and ignorance) I always choose helmet sizes based on comfort, I used to always measure my head right on the top of my eyebrows and assumed that my melon is 61cm, all my helmets are XL (61-62cm) sizes. After reading several internet references and re measured my head by circumference on 2.5cm above my eyebrows I am actually 59-60cm or L size.
I don't know what sin my mom and dad made when they made me but my melon is oddly shaped, on 60-61 (XL) helmets my cheek and eyebrows area fit snugly and comfortably (can't slide my finger between eyebrows area) but the top of my head and the back of my head is definitely a bit lose, so when I deliberately hit the back bottom part of my helmet with upward direction hit it will slide forward down covering half of my eyes even with tightly secured strap, it doesn't come off but it definitely slide a bit. On the other hand 59-60cm (L) sized helmets feels very comfortable and nice snug for the top and back of my head but my eyebrow and R/L temple area suffer really bad to the point I get migraine or headache after an hour ride. This applies to all brands I've tried/owned and due to my paranoia I bought 4 different helmets in the last 5 days, Shoei Neotec, X-Lite X-802RR, Schubert C3 Pro , Nolan N87. The best fitting so far is Schubert C3 Pro XL but I definitely can feel there is at least one finger wide gap right behind the top of my head...
Am I just being too paranoid and a little gap here and there is fine? I definitely cannot endure wearing 59-60cm (L) size on all the brands I've tried due to the discomfort and pain but I am afraid 61cm (XL) size won't protect my melon properly.. advice please, this paranoia is getting really expensive for refund policy does not exist in my country.
Sent from my MI 6 using Tapatalk
MY11 1090RR
uwiik is offline
post #2 of 26 (permalink) Old 07-16-2017, 02:09 AM Thread Starter
uwiik's Avatar
This is how much the helmet slides forward on back hit test simulating typical crash (based on X-lite user manual) on Shoei Neotec XL
MY11 1090RR
uwiik is offline
post #3 of 26 (permalink) Old 07-16-2017, 02:09 AM Thread Starter
uwiik's Avatar
This is how much the helmet slides forward on back hit test simulating typical crash (based on X-lite user manual) on X-lite X-802RR size L
MY11 1090RR
uwiik is offline
post #4 of 26 (permalink) Old 07-16-2017, 02:52 AM
I've just went through a similar experience on sizing a new helmet after a break from biking for a number of years. I watched all the 'experts' on YouTube and read a lot or articles on the internet. I ended up going to a good bike shop that supplied a wide range of helmets with the view that I'd be coming home with a Shoei X-Fourteen, after being measured at the shop and trying on the Shoei it was clearly not the helmet for the shape of my head. Next was an AGV Corsa-R and the assistant said it wouldn't suit my head shape, they were right. Next choice was an Aria RX7, which I was measured for and tried on. I was convinced the helmet was way too tight and would give me a major headache across my forehead. The guy rechecked the size and told me to go home and wear the helmet for a few days and it it would 'settle' to my head shape, if it didn't they would swap it with no questions. Wore the helmet and guess what, after a few rides, it's a perfect fit. My advice to you would be to get to a shop with a good reputation and have them fit the correct helmet shape and size for you. I chose a couple of high end helmets as my preferences but if it had come to it and the only one that would fit correctly was a 100 'lesser' brand then that's the helmet I would have purchased, you only get one head!
F3 800 MY16
Anamorphic is offline
post #5 of 26 (permalink) Old 07-16-2017, 03:31 AM Thread Starter
uwiik's Avatar
Did you get headache with the Arai RX7 during break in phase? I quite like the fit of my X-lite X802RR but I am still getting slight migraine after an hour ride, so far still only two rides.
MY11 1090RR
uwiik is offline
post #6 of 26 (permalink) Old 07-16-2017, 03:55 AM
First couple of hours wearing the Aria I felt some pressure on my forehead, it wasn't causing a headache, just some discomfort. I was convinced the helmet was too tight, if the discomfort has continued I wouldn't have been able to put up with it long term. I persevered and now it is a perfect fit.
F3 800 MY16
post #7 of 26 (permalink) Old 07-16-2017, 07:41 AM
Black_Gold_Saw's Avatar
U need to keep in mind that when u buy a helmet it needs to be tight, but not pressure on the head that u get an headache.
Overtime the fabric inside helmet gets softer and worn in and will fit your headshape and fit like a glove.
"Mileena"
Black_Gold_Saw is offline
post #8 of 26 (permalink) Old 07-16-2017, 08:10 AM Thread Starter
uwiik's Avatar
Did half an hour ride on my X-lite, I can tell that the pressure on my temple had decreased and I did not get massive headache, but discomfort and slight migraine was still there. I hope it will soften further. However, the pressure on my cheek is still very strong, perhaps I need to replace the cheek pads with the thinner option.
MY11 1090RR
uwiik is offline
post #9 of 26 (permalink) Old 07-16-2017, 08:15 AM Thread Starter
uwiik's Avatar
I came to understand that recently. However, like I described on first post, it wasn't easy with my head shape, it's either too tight on my temple (never forehead, just temples) and cheek causing pain on L size or nice tight fit on temples and everywhere else but loose on top of my head on XL size. Ughhh, I hate the shape of my head...
MY11 1090RR
uwiik is offline
post #10 of 26 (permalink) Old 07-16-2017, 08:28 AM Thread Starter
uwiik's Avatar
This drawing is what best describe my situation. Tried/own 5 different brands (Shoei-Arai-Schuberth-Nolan-Xlite) with each brand resulting in similar situation. It seems that my head in the middle between L and XL size.
MY11 1090RR
uwiik is offline
