Wiring in a USB charging point - MVAgusta.net
post #1 of 13 (permalink) Old 09-07-2016, 11:41 AM Thread Starter
Ackers's Avatar
Had a quick search for "usb charge" and "switched live" and didn't find anything so thought I start a thread.
If there is the info I need please point me in the right direction....
I have just bought a Givi Tank bag, just a little 4ltr one but it's ideal for what I need and it matches the Stradale's panniers bang on
It has a window'ed pocket in it for your phone/satnav so was planning to run some sort of USB to it for charging.
Looking at something like this:
Then I thought about how weatherproof the socket is if your plugged into it (being mounted on the bars it's going to be in the elements so though about splicing a 2 pin waterproof socket in line and mount the USB end inside the tank bag, so you effectively plug the tank bag in. Using something like this:
The USB charge cable is fused but wired to be connected direct to the battery? Is this ok or would you recommend wiring it to a switched live which comes on with the ignition? In which case where would you wire it up to?
Thanks for your help/constructive comments
Interested in anything that Sucks, Bangs and Blows!
Ackers is offline
post #2 of 13 (permalink) Old 09-07-2016, 12:07 PM
bogie's Avatar
I just use an adapter with my SAE optimate charge lead. The charge lead comes out near the neck and when I want to use it to charge my USB device (phone) I just plug in the adapter. It wires straight onto the battery
https://www.amazon.co.uk/Terminal-Ha...ae+usb+adapter
cheers
bogie
_________________
2015 Brutale 1090RR
bogie is offline
post #3 of 13 (permalink) Old 09-10-2016, 02:03 AM
idahomike's Avatar
Send a message via Skype™ to idahomike
Battery Tender makes the same style adapter for under $10 US on Amazon
Life Is Short, Eat Dessert First!
2007 Ninja 650R Candy Plasma Blue (Blue Thing) -SOLD
2013 F3 675 Red/Silver (Velocita) -SOLD
2014 899 Panigale Red (John Wayne)
2016 F3 675 RC #26 (Luisella)
2015 KTM RC 390 Cup
idahomike is offline
post #4 of 13 (permalink) Old 09-10-2016, 03:28 AM
These days it's very important to check the Output Amperage Capacity of the charger, most phones need between 1.8-2.4 Amp to charge and work at the same time.
post #5 of 13 (permalink) Old 09-10-2016, 05:16 AM
bogie's Avatar
yeah thats what I have, just the battery tender adapter on existing lead that was already on the bike...
cheers
bogie
_________________
2015 Brutale 1090RR
bogie is offline
post #6 of 13 (permalink) Old 09-12-2016, 03:05 PM
Yup, yup and yup. Works perfectly and no mess.
2014 F4 RR
2008 Yamaha Raider S
1982 Suzuki GS850L
fingertight is offline
post #7 of 13 (permalink) Old 09-13-2016, 12:52 PM Thread Starter
Ackers's Avatar
It only bloody works
Cut the battery terminals off the USB lead I bought and wired in a socket that fits directly to the Stradale's battery tender socket
Then cut the other end of the cable and wired in my waterproof 2 pin connector through the Givi bag leaving a neat socket outlet
So now inside the bag is a dual USB point
Just need to route the cable into the bike, job done
Cost 10 (plus the tank bag 45 off eBay)
I believe Givi want something like 70 for a similar solution
Ackers is offline
post #8 of 13 (permalink) Old 09-13-2016, 02:07 PM
^ Pretty slick. Throw an LED in there to see at night and you're golden.
2014 F4 RR
1982 Suzuki GS850L
post #9 of 13 (permalink) Old 09-22-2016, 02:24 PM
Jogort's Avatar
Looks perfect, where did you get the socket that fits onto the battery tender socket ?
Current steed - MY16 Dragster RR
Previous Bike - 2008 Triumph Street Triple
Scottish and living it up in South East Spain
Jogort is offline
post #10 of 13 (permalink) Old 09-22-2016, 03:53 PM Thread Starter
Ackers's Avatar
Got it all from eBay. Just search for waterproof electrical connectors, you find them in motoring section
Ackers is offline
The Following User Says Thank You to Ackers For This Useful Post:
