Charger plug for navigation - MVAgusta.net
post #1 of 8 (permalink) Old 07-04-2015, 07:01 AM Thread Starter
BrutaleHornet's Avatar
Gents,
I did a forum search but could not find any info.
Is it possible to connect the charger plug under the seat of my Dragster with a navigation system?
The plug has 12+V on it but I don't know if it gives any troubles with fuses...
And does somebody know where to get the female part for this plug? Or it's official name so I could google it.
Thnx !
Cheers,
Joost
Currently riding:
- 2014 Brutale 800 Dragster
- Moto Guzzi California III injection
Sold:
- 2004 Brutale 750
- Some Japanese stuff (everybody makes mistakes
BrutaleHornet is offline
post #2 of 8 (permalink) Old 07-04-2015, 01:49 PM
colinpp's Avatar
I've believe that they are known as Superseal connectors. Do a search on eBay and you should find some.
colinpp is offline
post #3 of 8 (permalink) Old 07-05-2015, 08:16 AM Thread Starter
Thnx mate, just ordered some
Cheers,
Joost
Currently riding:
Sold:
- 2004 Brutale 750
post #4 of 8 (permalink) Old 07-06-2015, 08:04 AM
Exclamation ?
don't forget you want switched, fused power.......don't think that plug is .......
check your wiring diagram
post #5 of 8 (permalink) Old 07-08-2015, 05:53 AM Thread Starter
That's correct, this plug isn't fused and switched.
I'll fuse it myself if the navi isn't.
Thnx for the tip
Cheers,
Joost
Currently riding:
Sold:
- 2004 Brutale 750
post #6 of 8 (permalink) Old 07-08-2015, 04:09 PM
Joost;
for small things I use the parking light circuit
that way I can't forget to turn the device off
post #7 of 8 (permalink) Old 07-15-2015, 06:51 PM Thread Starter
Thanks for the tip Noel, the Dragster isn't equiped with a parking light as far as I know...
I also thought about the brake-light, but this charger plug will do fine I think.
The navi wire has a fuse so that problem is solved.
Only thing I need next is a little time to install all of this....
Cheers,
Joost
Currently riding:
Sold:
- 2004 Brutale 750
post #8 of 8 (permalink) Old 07-20-2015, 05:36 AM
cruiser's Avatar
Like Noel, I also used the parking light circuit to power my Valentine1 (Hardwired configuration - yes radar detectors are not illegal in NZ).
Most car-audio shops can build you a 12v cable with the appropriate connector (including a fused wire if required).
...or you can wire it yourself ?
I had then build multiple as I've found them usual across a number of bikes. I usually access the circuit behind the headlight cover.
Tim
Tim
Current
MV Agusta Brutale 1090RR
Past
MV Agusta Brutale 750s
cruiser is offline
