05-F4 upgrade to 07-09 F4 - MVAgusta.net
post #1 of 8 (permalink) Old 11-27-2013, 12:23 PM Thread Starter
PhilAgusta's Avatar
Correct me if I am wrong,
I am thinking upgrade my 05-F4 1000 to 07-09 F4 here are the lists I would need.
1- hardness cable
2-ECU/ or race ecu
3- New TPS
Do you think my 05-F4 1000 would it gain some 10-20hp after those about upgrade? would the engine handle it?
07-MV Senna 201/300 My wife gift for my BD
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
09-Ducati 848 Her bike turn in track bike
PhilAgusta is offline
post #2 of 8 (permalink) Old 11-27-2013, 12:35 PM
The TPS should be on the throttle body of the engine you are upgrading to. You don't need to change it. Just the wire harness and ECU. You may have to change or re wire the switch for the blinkers/horn/headlight and the starter switch. If I remember correctly on the '07 models are wired differently.
post #3 of 8 (permalink) Old 11-27-2013, 12:43 PM
Ignition coils.....stick coils for each cylinder on the 5SM models.
post #4 of 8 (permalink) Old 11-27-2013, 02:52 PM Thread Starter
PhilAgusta's Avatar
if I upgrade those above items, Do you think I can get 10-20hp more Carl?
Thanks,
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
post #5 of 8 (permalink) Old 11-27-2013, 03:07 PM
Are you talking about swapping out the entire engine, or just changing the parts we are discussing. In my opinion just changing those items will result in no noticeable increase in horse power.
post #6 of 8 (permalink) Old 11-27-2013, 04:01 PM Thread Starter
PhilAgusta's Avatar
I see, thank you so much Carl
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
post #7 of 8 (permalink) Old 11-29-2013, 03:58 AM
gotojoe's Avatar
You'll have to change the engine Phil to to get any benefit ; )
The later engine has a camshaft position sensor too and the ebs relay function is now provided by the ecu rendering the "matchbox" ebs relay redundant...
joe
gotojoe is offline
post #8 of 8 (permalink) Old 11-29-2013, 10:38 PM Thread Starter
PhilAgusta's Avatar
Thank you Joe
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
