Lost part need advice. - MVAgusta.net
post #1 of 7 (permalink) Old 04-13-2013, 05:09 PM Thread Starter
R1andrew's Avatar
While out on my ride today I discovered I somehow lost the nut and pacer plate for the main swingarm bolt. This is the bolt which holds the swingarm to the frame plates. What are my options for replacing the spacer? I can contact Carl and get a OEM replacement or, and you guys know me. Is there a lighter nicer option? I will be replacing the nut with another titanium like before. That was a $30 mistake. Just glad I discovered this before something bad happened. Not sure how many miles I covered today before I lost the nut and spacer
R1andrew is online now
post #2 of 7 (permalink) Old 04-13-2013, 05:15 PM
rickyleesurf's Avatar
You are a lucky man!!!
Here's one...........
https://tpoparts.com/cat093/index.ph...product_id=268
rickyleesurf is offline
post #3 of 7 (permalink) Old 04-13-2013, 06:10 PM Thread Starter
R1andrew's Avatar
That is the bolt I have. Will be ordering the replacement nut today. Not sure what to do about the spacer plate I lost. OEM or is there a lighter option.
post #4 of 7 (permalink) Old 04-13-2013, 07:44 PM
JDS
King of Bling
JDS's Avatar
Send a message via MSN to JDS
http://www.evolutionbike.it/mvagusta...dtl003028.html
EMAIL :
JDS is offline
post #5 of 7 (permalink) Old 04-14-2013, 02:22 PM
Now if only all of you MV riders hadn't just simply ignored this thread....http://www.mvagusta.net/forum/showth...light=swingarm
post #6 of 7 (permalink) Old 04-14-2013, 10:23 PM
Pretty sure the plate is aluminum which is going to be the lightest metal you'll find to fit in there. To keep it from backing off again try using a lock washer. There is the good old american way of brute force by way of a split washer with a twist to it which applies constant tq. pressure, or one might be able to source a 'ribbed' washer(for lack of better term). If you have had the chance to see a washer on the STM clutches you'll see what i mean. Those little ribs at as teeth that provide enough bit to opposing surfaces to keep them from moving.
Ooooor, that spacer plate is large enough one could drill a few decorative holes in a circular pattern around the large hole. By doing this one can use 2 of those cosmetic holes for anchoring safety wire before wiring it to the bolt itself. Obviously will need to drill the bolt head too.
Pretty sure i have a spare spacer plate. If you need one just pm me your address.
varium is offline
post #7 of 7 (permalink) Old 04-14-2013, 10:30 PM Thread Starter
R1andrew's Avatar
Thanks for the offer. I contacted Carl today and will have one in the mail tomorrow. Hope to have the nut by the end of the week.
