It is true that without the dbkillers lose horsepower ? - MVAgusta.net
post #1 of 13 (permalink) Old 01-27-2013, 03:42 AM Thread Starter
SpainF4's Avatar
Hi guys.
the other day on a track day, a mechanic told me that without dbkillers,I'm losing horsepower, What do you think?
Enviado desde mi GT-N7100 usando Tapatalk
SpainF4 is offline
post #2 of 13 (permalink) Old 01-27-2013, 05:44 AM
MihaSLO's Avatar
Generally speaking, you lose power WITH dB killer.
If you gain power on a bike with installing the dB killer, than the exhaust wasn't designed properly in the first place.
MihaSLO is offline
post #3 of 13 (permalink) Old 01-27-2013, 10:44 AM
lee
lee's Avatar
I would disagree with the losing power without the DB killers. If anything there should be a bit more power due to the lower restriction in the end of the silencer.
Exhaust flow (both speed and volume) is an interesting topic and goes hand in hand with intake flow. I think you're just fine without the killers. In fact maybe a teeny bit lean if it was set up with them installed.
lee is offline
post #4 of 13 (permalink) Old 01-27-2013, 05:48 PM Thread Starter
SpainF4's Avatar
OK thanks guys!!!
SpainF4 is offline
post #5 of 13 (permalink) Old 01-29-2013, 06:36 AM
X81
here pigeons have some cats
To throw the cat amongst the pigeons you can gain or lose power with DB killers.
It depends entirely on the exhaust design but also cam design, air box air flow, filter, velocity stacks, port design.
I've had bikes make power with baffles fitted, not lose any power with baffles removed or lose masses of power with baffles fitted.
Even on 4 strokes you need an element of back pressure so a fully open pipe can have the opposit eeffect to what is intended and actually caue flat spots, holes in mid range or poor flow at high rpm.
So in answer to your question it depends entirely on the bike and exhaust system and ther eis no cast iron rule, only a guide that says check everythign ona dyno and make a decision based on resutls only and not gossip
X81 is online now
post #6 of 13 (permalink) Old 01-29-2013, 08:59 AM Thread Starter
SpainF4's Avatar
Yes,more interesting..answer is in the dino.
SpainF4 is offline
post #7 of 13 (permalink) Old 04-21-2013, 03:12 AM Thread Starter
SpainF4's Avatar
I have the answer, YES LOSE, we checked,specifically 2hp.
1.-Test ECU OEM whitout dbkillers:165 cv
2.-Test ECU OEM with dbkillers: 167cv , + 2 cv
Sent from Motorcycle.com App
SpainF4 is offline
post #8 of 13 (permalink) Old 04-21-2013, 04:59 PM
BSR-1's Avatar
2HP?
Did you do multiple runs with each set up?
2018 Husky 701 Supermoto
2018 Aprilia Tuono 1100
BSR-1 is offline
post #9 of 13 (permalink) Old 04-21-2013, 05:36 PM Thread Starter
SpainF4's Avatar
Originally Posted by BSR-1 View Post
2HP?
Hi.
Not, for see this may be 4.
For setting ECU M227 may be more than 90 runs, all with dbkillers.
SpainF4 is offline
post #10 of 13 (permalink) Old 04-22-2013, 02:18 PM
firedancer's Avatar
how is the bike now running with the microtec?
firedancer is offline
