Re: Replaced mid fairing (2010F4). Insulation suggestions? - MVAgusta.net
post #1 of 6 (permalink) Old 07-21-2012, 01:09 AM Thread Starter
toddburk's Avatar
Looking for some input from some of you members that are more mechanically adept. I recently replaced my side fairings (CF for stock) and was curious if anyone's done the same? If you have, what did you insulate(heat shield) the fairings with? Buy new insulation/heat protection, use existing heat shield, or did you create your own custom heat shield (if so what did you use)?
T.
2007 F41000R
2010 Ducati SF
2008 MV Brutale 910 S
2007 Ducati Monster S4Rs
2006 Triumph Speed Triple
toddburk is offline
post #2 of 6 (permalink) Old 07-21-2012, 01:34 AM
Dr. Duc's Avatar
Purchased new heat shields. Kept the originals as is in the event I need to swap out the carbons.
Ride fast and furious but live to ride another day!
Dr. Duc is offline
post #3 of 6 (permalink) Old 07-21-2012, 03:31 AM
adecritten's Avatar
Originally Posted by toddburk View Post
Looking for some input from some of you members that are more mechanically adept. I recently replaced my side fairings (CF for <a class="inlineAdmedialink" href="#"><a class="inlineAdmedialink" href="#">stock</a></a>) and was curious if anyone's done the same? If you have, what did you insulate(heat shield) the fairings with? Buy new insulation/heat protection, use existing heat shield, or did you create your own custom heat shield (if so what did you use)?
T.
I produce the Thermal Insulation Kits for the F4 from the exact same material that MV Agusta use, I would have no problem making a kit for the Y10.
Please PM me with your requirements.
adecritten is offline
post #4 of 6 (permalink) Old 07-22-2012, 01:42 PM Thread Starter
toddburk's Avatar
Thanks Ade. Im afraid the GBP exchange, fees and freight charges do not warrant but if I change my mind Ill drop a PM.
2007 F41000R
2010 Ducati SF
toddburk is offline
post #5 of 6 (permalink) Old 07-22-2012, 04:37 PM
I used Thermo-tec adhesive heat shield and cut them to the stock size.
Roadrunner1 is offline
post #6 of 6 (permalink) Old 07-22-2012, 08:20 PM Thread Starter
toddburk's Avatar
Thanks Roadrunner.
2007 F41000R
2010 Ducati SF
toddburk is offline
