swing arm pivot cover plate. - MVAgusta.net
post #1 of 21 (permalink) Old 07-08-2012, 01:35 PM Thread Starter
BG Wells's Avatar
Made these cover plates for the swing arm pivot bolt. Made others ages ago and there's a thread somewhere....but these are my latest.
I'll not bore you with photos of the process as in the past...but 'cut to the chase' with the end result....'lots' of work as usual..but I'm very happy with the result and hope you like em.
Brian
BG Wells is offline
post #2 of 21 (permalink) Old 07-08-2012, 01:49 PM
cdamb's Avatar
B750 and B1078 RR both gone now.
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."~Mark Twain
cdamb is offline
post #3 of 21 (permalink) Old 07-08-2012, 01:51 PM
Did you make the rear sets?
post #4 of 21 (permalink) Old 07-08-2012, 02:30 PM
R1andrew's Avatar
Very nice work.
R1andrew is online now
post #5 of 21 (permalink) Old 07-08-2012, 05:50 PM
SpainF4's Avatar
Nice !!
Sent from my Samsung using Tapatalk
SpainF4 is offline
post #6 of 21 (permalink) Old 07-09-2012, 03:26 AM Thread Starter
BG Wells's Avatar
...no they are 'sato' I did however make the 'knurled' shift peg on the end of the levers as the ones supplied were hard black plastic...and I thought a little 'cheap' looking.
Brian
BG Wells is offline
post #7 of 21 (permalink) Old 07-09-2012, 04:26 AM
lonerider's Avatar
Hi Brian , can you bore me with the whole proccess and pics please .
lonerider is offline
post #8 of 21 (permalink) Old 07-09-2012, 06:16 AM Thread Starter
BG Wells's Avatar
Hey Ian...if you'd like me to post up the photos of the sequence and process of how I made them then no problem...I'll happily do so.
I just thought that a load of 'in sequence' photos like ..eg. the 'bar ends' I recently done http://www.mvagusta.net/forum/showthread.php?t=47158 might not appeal to everyone...(like showing someone your holiday photos). I'm glad your'e interested though...and find it encouraging.
Brian.
BG Wells is offline
post #9 of 21 (permalink) Old 07-09-2012, 07:04 AM Thread Starter
BG Wells's Avatar
Ok Ian...seeing as you asked...
The photos show previously made 'cover plates' and as I wanted these new ones to have the same 'profile' I set up the machining process accordingly.
I also wanted the 'retaining nuts' to have a 1mm brass spoked wheel design and also have the same profile. These have to be made in a larger solid section and then 'separated' upon completion.
The 'plates are held in place via a threaded 'spindle' (not photographed) passing through through swing arm pivot bolt.
Anyway I hope the photos convey some of what was involved
Brian:
BG Wells is offline
post #10 of 21 (permalink) Old 07-09-2012, 07:28 AM
Brian my friend, you are a nut, a very good one though. I am getting some Ti brake caliper capscrew's, and I'm worried about how to drill them for safety wiring. You make us look whimpy indeed.
PS. Bloody glad i don't have to clean your bike.
