2010 F4 Slip-on exhaust valve elimination - MVAgusta.net
post #1 of 10 (permalink) Old 12-21-2011, 02:54 PM Thread Starter
LCSerrato's Avatar
I just purchased a BODIS slip-on exhaust for my 2010 F4, it comes without the valve that the stock slip-on has on it. I would like to know how to eliminate the mechanism that modulates that valve open and closed. It seems like I have to remove the cables from the electric motor (servo) and just leave the electric motor in its place functioning electrically. If I remove the motor altogether, it will confuse the computer thinking the motor went bad, causing CHECK ENGINE LIGHT or worst. If anybody out there has done this modification or knows what is the correct way to do it, I would greatly appreciate the help.
Thanks,
Lou
LCSerrato is offline
post #2 of 10 (permalink) Old 12-21-2011, 03:49 PM
lmcmulle's Avatar
in a related note. if one were to want to leave that value permanently open, how would you do that?
lmcmulle is offline
post #3 of 10 (permalink) Old 12-21-2011, 07:59 PM
hyperF4's Avatar
Just remove the cables from it and let it be. The motor will just think it's working. No biggie
Chris
hyperF4 is offline
post #4 of 10 (permalink) Old 12-22-2011, 08:21 AM
lmcmulle's Avatar
Chris, so not under tension the valve's state is open?
(the service manual is notably short on guidance regarding hacking the bikes emissions).
lmcmulle is offline
post #5 of 10 (permalink) Old 12-22-2011, 08:39 AM
hyperF4's Avatar
I believe so. The motor only acts to control the valve, but if it's not hooked up then it will just flap open when you have the bike running. The new slip on will eliminate this valve and you'll just remove the cables from the motor and the ECU will still think it's all good since the motor is still hooked up. I have done this on friends Ducati and Yamaha. If you have the stock exhaust on and remove the cables, then it will get a little louder as well.
Chris
hyperF4 is offline
post #6 of 10 (permalink) Old 12-22-2011, 12:12 PM
The valve is spring loaded to full open. That is the fail safe default should a cable break.
post #7 of 10 (permalink) Old 12-22-2011, 04:37 PM Thread Starter
LCSerrato's Avatar
Thanks for all the input. What I ended up doing which was recommended by Speers Racing the manufactures of the BODIS exhaust is disconnecting the cables from the electric motor and removing them with the stock slip-on. Works great run beautiful! I'm very happy with the results.
Thanks,
Lou
post #8 of 10 (permalink) Old 12-22-2011, 05:37 PM
Cool....PICTURES?!
post #9 of 10 (permalink) Old 12-23-2011, 11:54 PM Thread Starter
LCSerrato's Avatar
2010 F4 with new BODIS
Here are the photos!
Sorry it took so long to post photos, got busy. Lou
http://youtu.be/F6M-qjXneMk
post #10 of 10 (permalink) Old 12-25-2011, 06:44 AM
MVAgusta.net Sponsor
mitchy's Avatar
Lou,looks and sounds great mate.
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is online now
