Chrono Time Gear Indicator Problem - MVAgusta.net
post #1 of 11 (permalink) Old 12-04-2011, 11:54 PM Thread Starter
Tricolore's Avatar
I have just installed the gear indicator, apparently plug and play...
Plugged it in and there's nothing, nada, nil.
I have previously disconnected the headlight and l/h switch block has been removed, would that affect the power supply?
Need help, the light and switch block are in the back of the shed somewhere and I don't want to unpack everything and rifle through the boxes to find them and discover it has nothing to do with them, plus its a track bike so I will not be using them anyway.
Ideas and input would be great.
Thanks guys and gals.
Tricolore is offline
post #2 of 11 (permalink) Old 12-05-2011, 12:36 AM
I used the acumen with the plug & play loom and it didn't work either. Soldered the gear indicator directly into the bike loom and worked fine.
ironbar is offline
post #3 of 11 (permalink) Old 12-05-2011, 04:58 AM
King of Carbon
DesignCorse's Avatar
The Crono Gear indicators only work once the headlight is switch on. It will not turn on otherwise as it gets the pick up from there.
Regards
Al
T: +44 (0) 1582 840 024
DesignCorse is offline
post #4 of 11 (permalink) Old 12-05-2011, 07:22 PM Thread Starter
Tricolore's Avatar
So does that mean I have to cut the wires from the alleged "plug and play" loom and take power from elsewhere?
post #5 of 11 (permalink) Old 12-05-2011, 10:34 PM
Question Plug n play ?
Hi Steve
Where would this normally plug into, got some pics. The gear indicator I have plugs into the dash. On the 1000R, and I am not sure on the 750, if you turn the bike on then the lights come on too ?
post #6 of 11 (permalink) Old 12-05-2011, 11:52 PM Thread Starter
Tricolore's Avatar
Hi Steve
It just piggy backs into the dash. The issue is I dont have lights or switches because its a track bike. I have never had lights so not sure if the lights come on with ignition.
post #7 of 11 (permalink) Old 12-06-2011, 12:07 AM Thread Starter
Tricolore's Avatar
Common sense would suggest that the power supply come from the ignition, not the lights. Makes the thing pretty bloody useless for track / race application (where it is most commonly used )
post #8 of 11 (permalink) Old 12-06-2011, 12:10 AM
Exclamation
Have a good look at your wiring diagram, you might be able to just re-fitt the lighting fuse, or put a bridge in from one of the other power feeds. I did my whole wiring loom on the weekend, if you get stuck give me a ring later this arvo, I will be home by 5, WA time.
post #9 of 11 (permalink) Old 12-06-2011, 04:17 AM
King of Carbon
Indeed, the Crono gear indicators are not the best for track bikes due to this. I would suggest if you cany wire it in manually then go for a Accumen DG8 like Dons is running as they dont require the same pick up as the crono version.
Regards
Al
post #10 of 11 (permalink) Old 12-06-2011, 04:23 AM Thread Starter
Tricolore's Avatar
Ok, I pulled the shed apart and found the left switch block, plugged it in and hey presto it works. Given that I would need to modify the wiring I will just leave the switch block in. I guess the only issue now is there is power to the light connector so I will have to seal it up and any other connectors incase water gets in and shorts out.
P.s. Donsy, FYI The light is powered to ignition on the 750 same as the 1000r.
Thanks for you help mate.
