Up grading the cooling system with Febur and Oil radiator - Page 2 - MVAgusta.net
post #11 of 20 (permalink) Old 11-21-2011, 01:11 PM
hb88xx's Avatar
you can see in the pic there is no 3mm foot gasket (neither a higher cil block)and you will have trouble mounting the sidebolts in the frame if you raise it 3 mm.
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
post #12 of 20 (permalink) Old 12-03-2011, 11:41 AM
MV-999R's Avatar
Originally Posted by a.flegra View Post
a.flegra does that brake/clutch fluid reservoir really works fine?
I have been wanting to get on for some time but never pulled the trigger because i was not sure how if really works in real life...
Who makes it? (i have a link for the site but don't seem to find it now)
And also do you know if it works fine with the Brembo RCS brake and clutch pumps?
MV-999R is offline
post #13 of 20 (permalink) Old 12-27-2011, 04:32 AM Thread Starter
Hi,
i have a new project rebuild my wsbk with magnesium and carbon parts back to the road with 1078cc but this later.
i demounted this mv with a red frame and sold the most parts.
The fluid reservoir really works fine but it is not cheap!
The German Superbike IDM Driver Teuchert are drive this 2001 on MV!
http://www.performanceparts.de/de/MV...PPLUNG-BREMSE/
http://www.kc-engineering.de/aid-713...ssstutzen.html
Uploaded with ImageShack.us
a.flegra is offline
post #14 of 20 (permalink) Old 12-28-2011, 04:42 PM Thread Starter
Hi,
i have this informations Donsyfor you!
No race is simple ..... the 750 is 43.8mm
the displacement is: the surface x race x No cylinders
73.8mm x 43.8 = 4277.62 sq mm x 4 cyl = 749.43 cc = 749439.7 mmc
76mm is the same calculation with a displacement of 794.8 cc (795cc)
and the 79mm is 858.8 cc (860cc)
Instead go to 81mm with a 902.8 cc (903cc)
all 750 43.8mm stroke can run up to 16500rpm rotation because that is the average piston speed of 24.1 m / s
admitted that the distribution is in fact the SPR runs behind ....( above)
a.flegra is offline
post #15 of 20 (permalink) Old 12-28-2011, 04:50 PM Thread Starter
79.0x55.0mm=1080cc
a.flegra is offline
post #16 of 20 (permalink) Old 12-28-2011, 09:41 PM
Thumbs up Thanks Adam
Very interesting invo.
post #17 of 20 (permalink) Old 12-30-2011, 02:00 PM Thread Starter
For my new engine the new Febur oil radiator
a.flegra is offline
post #18 of 20 (permalink) Old 01-02-2012, 10:51 AM
MV-999R's Avatar
Hi,
Thanks Adam
Do you know if it fits the Brembo RCS pumps?
MV-999R is offline
post #19 of 20 (permalink) Old 01-02-2012, 11:07 AM
Post yup
Originally Posted by MV-999R View Post
Thanks Adam
The reservoir just takes the two lines straight from the RCS at two entry points. It really is just a bigger fluid container, I took mine of because it takes up too much room and fluid.
For road use I think it's pretty good though, but I still think it's a pretty good idea, just could not make it fit under my race fairing and all the other plumbing.
post #20 of 20 (permalink) Old 01-02-2012, 02:15 PM
Al-
Al-'s Avatar
is there really enough wall thickness to go 81mm bore on a 750 motor?
Al- is offline
