Fanzilla question - MVAgusta.net
post #1 of 9 (permalink) Old 08-14-2011, 12:37 PM Thread Starter
nickinhouston's Avatar
Fanzilla question
I am installing the 3rd fan this weekend and I have everything mounted and was fixing to wire it in . My question is do I have to run the 3rd fan on a seperate relay or can I just splice it into the upper fan ? I searched the forum and found where some guys were running the bosch relay and I believe I seen where some guys just directly wired it in . Thanks for any help
nickinhouston is offline
post #2 of 9 (permalink) Old 08-14-2011, 03:23 PM
Correct.
post #3 of 9 (permalink) Old 08-14-2011, 06:55 PM
lee
lee's Avatar
As Fanzilla's Father kindly allow me to prattle on about the wiring. It has been done either way. I prefer the separate circut from the battery with it's own fuse, relay and switch. For the simple reason that it can be run with the ign off and engine stopped. 45 seconds or so of running three fans cools things down under the fairings in the front of the engine really quickly and it doesn't sit there frying itself to death.
The total current draw of the three fans is well under 10 amps and the battery has no problem running the fans for a brief period. In fact I forgot to shut them off once for about ten minutes and the engine started right up.
Course you could just leave the ign on and use the kill button.
lee is offline
post #4 of 9 (permalink) Old 08-14-2011, 07:46 PM
V10KLZZ71S's Avatar
Can this be done on a Brutale? 2 fans.....
07 Brutale' 910R Arrow Thunder, PCIII,Ferracci chip, CRG mirrors,levers. Scotts, Motovation sliders.
O6 Yamaha FZ1
V10KLZZ71S is offline
post #5 of 9 (permalink) Old 08-14-2011, 11:13 PM Thread Starter
I dont know how the brutal radiator/fan set up is but if your looking to just have control of your fans search the forum for the manual switch mod , It helped mine alot but i need a little extra in stop and go traffic . Im hoping this third fan will allow me to remove the switch and allow the bike to cool by itself
post #6 of 9 (permalink) Old 08-15-2011, 04:50 AM
lee
lee's Avatar
It won't. The switch is the key. There simply isn't enough airflow through the rads at low speed.
lee is offline
post #7 of 9 (permalink) Old 08-15-2011, 04:53 AM
Brutale's don't usualy have such a big heating issue Daryl.
post #8 of 9 (permalink) Old 08-15-2011, 10:50 AM
V10KLZZ71S's Avatar
I cringe getting caught in traffic, it will puke fluid on occasion. My level is on the lower side also. I am getting a new pump upgrade and muzzy fan installed right now so hopefully that will help. Might try the switch rig up though. I hate to say it but I can get caught in traffic on my Yamaha and never have to worry about temps. I wonder what temp thermostat we have. The manufacturers have to keep temps up to meet emissions testing. I wonder if a lower temp one could be found and used?
O6 Yamaha FZ1
post #9 of 9 (permalink) Old 08-15-2011, 11:34 AM Thread Starter
When I tested my thermostat it opened at 190ish . I drilled the holes open a little bit to allow more flow . If I were you I would try the manual fan switch before trying to mount another fan . The switch will only take 30 minutes if you take your time and make everything pretty
