Autotune update - MVAgusta.net
post #1 of 12 (permalink) Old 08-12-2011, 01:22 PM Thread Starter
lee
lee's Avatar
Autotune update
Was having some trouble with the thing not sending the lambda values. Found out that the #'s in the controller for the Can bus connections for I & 2 were wrong. Set in the right ones. This thing is the answer ladies. No ifs, ands or buts. Set the A/F in the window at 13.5/1 from idle, closed throttle to 7000 rpm 50% throttle. Good a place as any to start. Went out and rode. It set the idle at 13.5+/- (tough area) and everywhere else I had it at 13.5+/-. This was with a tolerance of .5 on the A/f. Going to slowly narrow it down on succsessive runs.
It idles smoothly now and does not skip a beat. The bog off idle is gone- very smooth flow of power. All that skipping/missing at low throttle/rpm is gone. Smooth and even. And although I don't have a dyno, the seat of my pants tells me it is making better acceleration and alot more linear and smooth. Exhaust sounds better as well- not fat or sharp.
So, if you have a Microtech and your bike still runs less than you feel it should I highly recommend this thing. I still have alot of fiddling to do with it but from what I see so far, in my opinion, it's as good as a dyno and maybe better as it tunes in real world conditions at all rpm's and throttle openings.
For the first time in a long time I came back from my putt with a smile on my face and felt happy. That's been awhile, I'll tell you. The day may very well come when I cease referring to the Duc as "my shitbox".
Going to a local bike night tonight and lay on the grass, eat hot dogs, swill a Pepsi and relax. I'm tired.
lee is offline
post #2 of 12 (permalink) Old 08-12-2011, 05:05 PM
1. So you are running the autotune on a Ducati?
2. How would someone with very basic computer skills go using the Autotune?
3. How do you go about tuning top end on the road? [Big speeds]
4. And last of all do you mind telling where you got the autotune and how much please?
5. Did you have to put plugs in the pipes for the lambdas?
I have a Microtec ECU to go on my Duke, but no one here much to set it up and was thinking that the autotune might be an option but I'm not very good with computers so have been a bit put off by that.
bstar360 is offline
post #3 of 12 (permalink) Old 08-12-2011, 05:14 PM
rents's Avatar
That's the best part
rents is offline
post #4 of 12 (permalink) Old 08-12-2011, 08:08 PM
hb88xx's Avatar
running two lambda's?
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
post #5 of 12 (permalink) Old 08-13-2011, 04:47 PM Thread Starter
lee
lee's Avatar
Yes. Dual lambdas.
If you aren't very good with computers then I'm not sure I'd get the autotune. I'm not half bad on them and this thing has driven me nuts learning how to work it.
Tuning top end is probably a bit tougher to do as the engine winds so fast it doesn't have much time to grab the cel and mod it. Best you can do is make slow throttle movements in lower gears and hope it gets it.
Got it from the Ducshop. $$$$$ is all I'm going to say.
I have an Arata pipe on the duc and it came with two lambda bungs in it.
lee is offline
post #6 of 12 (permalink) Old 08-13-2011, 09:51 PM
Thanks.
bstar360 is offline
post #7 of 12 (permalink) Old 08-14-2011, 03:04 PM
hb88xx's Avatar
it's on sale!?
http://www.ducshop.com/product_view.php?cat=7&pid=384
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
post #8 of 12 (permalink) Old 08-14-2011, 06:45 PM Thread Starter
lee
lee's Avatar
Yeah. Such a deal. Lotta' gelt. Oy !
lee is offline
post #9 of 12 (permalink) Old 08-20-2011, 02:08 PM
ThePerformanceOne's Avatar
13.5 is a good place to start
You might want to experiment with the 13.5 number. You will notice the engine will want a different A/F at Torque peak than it does at HP peak. Due to efficiency.
ThePerformanceOne is offline
post #10 of 12 (permalink) Old 08-20-2011, 03:20 PM
firedancer's Avatar
welcome to the forum
very nice bike in your avatar.
firedancer is offline
