Brake and Clutch line for RCS? - MVAgusta.net
post #1 of 12 (permalink) Old 08-11-2011, 10:48 AM Thread Starter
PhilAgusta's Avatar
Are we be able using oem brake and clutch line for RCS? or Do we need to up-grade new one? Can anyone point me where can I get it from?
Thanks,
Phil
07-MV Senna 201/300 My wife gift for my BD
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
09-Ducati 848 Her bike turn in track bike
PhilAgusta is offline
post #2 of 12 (permalink) Old 08-11-2011, 11:27 AM
Exclamation Hi Phil
I use the OEM clutch line, fits right in on the RCS16.
On the brakes I use a custom dual line set from HEL, ordered over the phone but using my own guessed lengths and fitting angles. They were really good price (+/-$120 delivered) but these guys are closer to you
http://www.spieglerusa.com/brakes/cu...ake-lines.html
and this is where I will order my next set from.
You should be able to use the OEM set on the brakes but I feel they leave too much room for bubbles and have less feel than individual lines, the RCS come with the right fittings to adapt.
Feel free to ask if you eed more info.
post #3 of 12 (permalink) Old 08-11-2011, 11:27 AM
Al-
Al-'s Avatar
for the short term I am using something like this to adapt the stock lines to radial masters
http://helperformance.com/store/prod...oducts_id=3520
In the long term I plan to order complete new lines from either HEL or Spiegler
2006 Brutale 910S
2012 F4 RR
2012 F4 RR
Al- is offline
post #4 of 12 (permalink) Old 08-11-2011, 11:32 AM
Al-
Al-'s Avatar
I'll also add that i agree with Donsy, it was a pain in the ass the bleed with that adapter setup on the brake side.
2006 Brutale 910S
2012 F4 RR
2012 F4 RR
Al- is offline
post #5 of 12 (permalink) Old 08-11-2011, 12:19 PM Thread Starter
PhilAgusta's Avatar
Thanks guys,
Did you guys use a sucker pump out fluid when you guys bleeding the brake? or do manual?
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
post #6 of 12 (permalink) Old 08-11-2011, 01:10 PM
Al-
Al-'s Avatar
I used a 60mL syringe to pull fluid from the top to the bottom, as i'd rebuild the brake calipers as the same time. After that I did some manual bleeding and then pumped the brakes a lot while i tapped the lines and fittings to get the air bubbles to rise to the top. I used the clear tygon tubing for the reservoirs so that i could see the bubbles continue to rise to the top. When I was finished with all this, I used a cable tie to depress the brake lever overnight (and for a couple days) during some really hot weather, and got the lever really nice and firm. This was only necessary because I was using beringer master cylinders not brembos. Brembos have a bleeder right on the MC, which makes bleeding them a piece of cake.
2006 Brutale 910S
2012 F4 RR
2012 F4 RR
Al- is offline
post #7 of 12 (permalink) Old 09-05-2011, 09:35 AM Thread Starter
PhilAgusta's Avatar
Guys,
my project hold off since Friday, I have a problem with RCS brake lever adjust nob hitting odometer, should I adjust the clipon back little? how did you guys install your brake master with this problem?
05-MV F4 Track bike
16-Ducati DVT-S
10-Ducati 1198R
08-Ducati 1098
post #8 of 12 (permalink) Old 09-12-2011, 09:11 PM
timmay's Avatar
Send a message via AIM to timmay
I used a spacer on the ohlins dampener, i'll take a picture and i'll send it to you phil.
timmay is offline
post #9 of 12 (permalink) Old 09-13-2011, 02:07 PM
Good idea - can you post the pic on here....
Adam
merc07 is online now
post #10 of 12 (permalink) Old 09-13-2011, 06:39 PM
lee
lee's Avatar
Make your own lines. Either braided stainless from Earls or Russell or the very small plastic lines and fittings from the Parker Store. They're a hydraulic supply outfit. Stuff is called "Parflex" and it's 3/16" in diam. I use them on all the bikes I build and they are the best setup I've ever seen. Good to 600psi and sooo easy to work with. Flexible, and can be curved with a hair dryer to fit tit.
lee is offline
