New Headlight Dra 800RR 15 - MVAgusta.net
  • 1 Post By ArnO
post #1 of 9 (permalink) Old 06-12-2019, 05:24 PM Thread Starter
Going for a new Headlight on a 2015 800RR
My plan is the New LED light from Th 2018/19 modell.
What do i need to do for it to work?
Want the DRL for the day (switch operated) low beam when nerder and high beam
Since i dont got a switch for on/off on the light i need to do it whit a third after mounted one. So i can chose DRL and DRL + low beam when needed.
Highbeam whit the std swhitch
Tnx in advance for tips
DragsterRRnor is offline
post #2 of 9 (permalink) Old 06-12-2019, 05:35 PM
Banned's Avatar
Interested to see how the works out as I'd like to do the same. I've also thought about putting a Rivale light on.
2015 Brutale 800RR
2015 F3 800
Banned is offline
post #3 of 9 (permalink) Old 06-12-2019, 06:12 PM Thread Starter
My only problem is canbus. Rewireing sould ve fine. But the rest do i ned resistors. And if yes how big 😛
post #4 of 9 (permalink) Old 06-12-2019, 09:25 PM
I don't know where you are based, but if you are in the US, keep in mind that the US part(s) doesn't allow us to enjoy the DRL.
If you get a 2019 Dragster in the US, you don't have a way to get the DRL only mode. There's no switch on the right-hand side controls like the EUR version.
I really like the DRL on the 2019, and I decided to order the EUR switch. I should get it in two weeks. One thing I am not sure is if the headlight itself is the same as the EUR one... we will see when I put the switch on and test it...
Long story short: if you are based in the US, make sure you get the EUR version of the switch and (maybe) the EUR version of the headlight.
ArnO is offline
post #5 of 9 (permalink) Old 06-13-2019, 02:11 AM Thread Starter
Am based in norway (EU)
My problem is That it dont support LED. So if the canbus system start throwing codes. Thats shit.
If i kan just re wire i kan use 3 point switch for DRL, DRL + low beam or low beam.
Since i got H4 light now one - and two + for low/High.
Also my light today is halogen. So LED can show up as a faulty bulb
And $800 for a lamp is mutch. Specialy if it dont work 😛
post #6 of 9 (permalink) Old 06-17-2019, 01:36 AM
htxbrute's Avatar
Let me know if this works for you. I have been thinking of ordering the EU switch to see if the DRL turns on. There seems to be only one part number on for the headlight on startwintrading.
htxbrute is offline
post #7 of 9 (permalink) Old 06-17-2019, 02:03 AM
Yes, it works. I installed the EUR switch this weekend. I posted an update tonight with some pics. Go check it out
silentservice703 likes this.
ArnO is offline
post #8 of 9 (permalink) Old 06-17-2019, 09:52 PM
bbycakes's Avatar
Hey. When are you going to post those pics? Would love to see what you did
bbycakes is offline
post #9 of 9 (permalink) Old 06-17-2019, 11:13 PM
Here you go my good sir: https://www.mvagusta.net/forum/53-br...rr-makeup.html
ArnO is offline
