TV/Stradale/Rivale/Dragster rear indicator original specs? - Page 3 - MVAgusta.net
 6Likes
post #21 of 32 (permalink) Old 05-03-2019, 02:07 PM
Teeps's Avatar
Originally Posted by MarcSilverTriple View Post
Teeps and others : how did you make the connexion?
Ordered terminated pig tails from ebay so I didn't have to cut the wire harness on the bike.
I'm in the process of making resistor pig tails to join with the after market signals.
https://www.ebay.com/itm/Ducati-Turn...EAAOSwajVUOGbN
Wire length (as it applies to our bikes) has nothing to do with hyper flashing.
(22 gauge wire has 16 ohms resistance per 1000 feet of wire.)
Easy enough to measure the resistance of the wire from end to end to make sure.
2016 Turismo Veloce 800
Teeps is offline
post #22 of 32 (permalink) Old 05-04-2019, 03:46 AM
Pablotv's Avatar
I reckon you could make a few of those and sell em on to us mere mortals😋
Pablotv is offline
post #23 of 32 (permalink) Old 05-04-2019, 10:22 AM
Teeps's Avatar
Yes, but there are too many variables and with shipping, would not be cost effective.
Teeps is offline
post #24 of 32 (permalink) Old 05-19-2019, 12:55 PM Thread Starter
MarcSilverTriple's Avatar
Found Led Indicators with 10W specifications. It works perfectly. Mounted them slightly differently than previous mounts:
I made the mount to put the connectors behind the registration plate to allow quick replacement
The indicators works perfectly, at the right frequency, and the light is highly visible
Now, this is still not perfect.
In anycase, it won't take 3 hours next time for replacement: should be ok in about 15 minutes.
Last comments: I have check Rizoma website after discussion with my dealer (basically some led indicators are hyperflashing engine running, some hyperflash anytime: it seems to be a lottery)
- Rizoma Action are given for 2 Watts. In my case one was hyper flashing while engine running, while the other one not.
- Kellermann Rhombus are given for 1.4 watts: hyperflashing while engine was running, both
- Gazzini COB LED: 9,9 W : no hyperflashing
- Rizoma Corsa is indicated by someone on this thread as not hyperflashing and is given for 1,4W. I saw a Dragster yesterday where it was hyperflashing.
- Rizoma Vision is given for 3.4W: there is good chances it is above the treeshold, which seems to be around 2W for my led flasher unit.
Teeps likes this.
Marc,
Turismo Veloce in France
Ride with us in Vosges :
MarcSilverTriple is offline
The Following User Says Thank You to MarcSilverTriple For This Useful Post:
post #25 of 32 (permalink) Old 05-20-2019, 09:59 AM
Teeps's Avatar
Nice job Marc.
Teeps is offline
post #26 of 32 (permalink) Old 05-22-2019, 04:23 PM
Gero HH's Avatar
I installed the Kellermann indicators strait away no resistors needed....
Gero
______________________
2016 Turismo Veloce 800 Lusso
Gero HH is offline
post #27 of 32 (permalink) Old 05-23-2019, 04:47 PM Thread Starter
Understand now why: those are the ones with two leds (3W). The version with one led is hyperflashing when engine is running. Thanks :-D
Marc,
post #28 of 32 (permalink) Old 06-12-2019, 11:04 PM
Christ! Talk about making things complicated. Obviously you lot are all military officers!!!!! No need to get upset pumpkins.
I have installed a pair of Barracuda IDEA LEDs on my TVL and a pair of parallel resistors of 150 ohms each to obtain the correct flash rate.
How did I determine the resistor value you ask?
Place a variable resistor, a trim pot(entiometer) will suffice, of 500 ohms across the two leads to the turn indicator, the wiper of the pot to one power lead and one end of the resistor track to the other power lead. Polarity is not important. Set the pot to max resistance. Switch on the turn indicator and slowwly turn the pot to reduce the resistance until the flash rate is correct. Deselect the turn indicator, disconnect the pot and measure the resistance. Select the next lower preferred value of resistor to install. I used a 1 watt.
NOTE**** the purpose of the resistor is to draw more current to obtain the correct flash rate, it is connected in parallel with the LED.
Hope that my attempt to attach a photo of the internals of the TVL front indicator has worked.
Teeps likes this.
cutloose is offline
post #29 of 32 (permalink) Old 06-13-2019, 12:57 AM Thread Starter
What??? No, we are just trying to fix italian Engineeri^h^h^h designer stuff
More seriously, anything above 2 Watts consumption is ok for direct mount in replacement of the rear indicators. No saying that, if you change as well the front ones, then you are likely to need resistor or higher consumption indicators.
Marc,
post #30 of 32 (permalink) Old 06-13-2019, 09:56 AM
Teeps's Avatar
Cool, no math required, way to determine needed resistance...
Teeps is offline
