PC5 or Microtec? - MVAgusta.net
  • 2 Post By The_castle
post #1 of 10 (permalink) Old 06-29-2018, 09:32 PM Thread Starter
NicholasF4's Avatar
PC5 or Microtec?
Just wanted to know which is better between PC5 and Microtec and why?
My bike is being put together now and itís up for Dyno time. I put the Bodis full exhaust on it and have made some various modifications on it.
Thanks!
1120 F4RC -2017 MOTUL. Euro 3. The last of the best of the best!
NicholasF4 is offline
post #2 of 10 (permalink) Old 06-30-2018, 12:58 AM
The_castle's Avatar
Contact Chris at X-Bikes regarding the Microtec ECU.
NicholasF4 and NicholasF4 like this.
The_castle is offline
post #3 of 10 (permalink) Old 06-30-2018, 09:26 AM
In a nutshell: The Microtec is a fully serviceable ECU that can set multiple parameters including A/F ratios, engine timing, fan on/off temperatures and can be used to control quick shifters and data logging.
PC5 is a band-aid add-on system with limited capabilities and potential for wiring and control issues.
Microtec is fully supported by X-Bikes Racing, Chris, who is a member here.
PC5 is not.
post #4 of 10 (permalink) Old 06-30-2018, 09:53 AM
@NicholasF4, I thought you had a 2017 F4RC? Microtec don't do an ECU for this model, only pre 2013 if i am correct (basically models before ride by wire).
Best option is ECU studio for your bike.
Or do you have another MV?
Dragster 800 2015
F4 RR 2013
F3 675 2012 Full Track Bike
Brutale 1090 RR 2011 - Sold
jhollis is offline
post #5 of 10 (permalink) Old 06-30-2018, 12:39 PM Thread Starter
NicholasF4's Avatar
Itís for my 2017 F4RC. Correct.
So I canít go with the Microtec then?
post #6 of 10 (permalink) Old 06-30-2018, 05:59 PM
Nope, its only for those F4's with cable operated throttle (someone do correct me if I am wrong)
I would say ECU Studio is your best option, it has been reviewed numerous times on here so have a look around.
Dragster 800 2015
F4 RR 2013
jhollis is offline
post #7 of 10 (permalink) Old 06-30-2018, 11:31 PM
Yeah.... You should have your ECU remapped to do everything you need.
A PowerCommander is a piggyback device that alters the ECU signals to the injectors and nothing more. Old technology and definitely a waste of your money.
post #8 of 10 (permalink) Old 07-01-2018, 08:50 AM
UnaRosa's Avatar
As one who has the "band aid" PCV with auto tune, I would recommend the same. All I can affect is fueling. Ignition timing is still controlled by my Race ECU.
If you can manipulate the ECU, that is your best option. Control the brain...
"he's going the distance, he's going for speed"
'10 Brutale 990R ("Sophia")
'14 K1600GTL (Tour de Force)
'15 1290R (Torque monster)
'85 KZ700 (my first)
UnaRosa is offline
post #9 of 10 (permalink) Old 07-01-2018, 01:11 PM Thread Starter
NicholasF4's Avatar
The PC5 is already installed. My bike will be totally done in 2 weeks.
So when I get it back I should turn it in to ECU Studios?
What can they help me with?
post #10 of 10 (permalink) Old 07-01-2018, 11:04 PM
Dansoarr did a comprehensive write up here:
http://www.mvagusta.net/forum/21-cus...es-update.html
Dragster 800 2015
F4 RR 2013
jhollis is offline
