Brutale 800 Rear Indicator Wires Assembly - MVAgusta.net
post #1 of 5 (permalink) Old 06-26-2018, 05:34 PM Thread Starter
rocky.ong's Avatar
Hello friends,
Did anyone ever try to replace the rear indicators on the new Brutale (MY2016 and above)? Iím trying to replace the stock indicator and put an aftermarket one by CRC racing. Completely puzzled by how the wires are run, it looks like the whole thing is run thru the whole side swing arm?
Looking for advise :thankyou:
rocky.ong is offline
post #2 of 5 (permalink) Old 06-27-2018, 07:21 PM
htxbrute's Avatar
Hey rocky.ong, if you look under the swing arm where the rear hub is, there is a small plastic cover where the connectors for the indicators and license plate light are. It would probably be easier to just take off the whole license plate holder from the swing arm to run the wiring for the new indicators.
htxbrute is offline
post #3 of 5 (permalink) Old 06-27-2018, 07:51 PM
Let us know how it all works when you figure it out Curious to see what you replaced the stock blinkers with
Finnigan is offline
post #4 of 5 (permalink) Old 06-28-2018, 02:21 AM Thread Starter
rocky.ong's Avatar
Gotcha. Ok I will try that. Thanks
I got one of these: https://www.cncracing.com/en/product...-approved.html I need to check how/where to connect all the wires though, seems pretty tricky this one.
post #5 of 5 (permalink) Old 06-29-2018, 11:12 AM
bbycakes's Avatar
I agree with htxbrute. You would have to remove the back side panels in order to get a better look and feel.
bbycakes is offline
Tags
brutale 800, indicators
