F3 Why Disconnect Exhaust Valve? - Page 2 - MVAgusta.net
 2Likes
post #11 of 23 (permalink) Old 06-04-2018, 06:25 AM
Black_Gold_Saw's Avatar
Originally Posted by MrTrogg View Post
Perhaps a silly question and sorry if this was covered elsewhere but is there any risk to the engine when running valve fully open or while riding to dealership with the fault on? If not I'll just yank the cables since I've currently got the malfunction happening....
Found this with a quick search.
"The purpose of this system according to the motorcycle manufacturers’ marketing departments is to create back-pressure at lower RPM’s to increase torque. Unfortunately, this probably isn’t the real reason; the true purpose of the exup valves is to meet noise and emissions regulations. The exhaust valves are partially closed at idle and low rpm to reduce noise, and closed again at the upper RPMs to meet peak noise and emissions regulations. The proof of this has been shown on the dyno where removing the valves and retuning the engine creates a flatter better torque curve. Additionally, in the USA, most bikes close the valve again at the upper RPM range, but in Europe they do not (different regulations) and the European bikes typically create a few more HP on the top end as a result."
"Mileena"
Black_Gold_Saw is offline
post #12 of 23 (permalink) Old 06-04-2018, 06:45 AM
That is mis-information.
post #13 of 23 (permalink) Old 06-04-2018, 06:52 AM
Wildfire's Avatar
Only if there is a change in exhaust note. If it's stuck closed then don't ride it until you disconnect it or check. You'll know if it's stuck closed as the when you rev it the exhaust will sound totally muffled.
Wildfire is offline
post #14 of 23 (permalink) Old 06-04-2018, 08:46 AM
Can't be wrong...it's on the internet!
post #15 of 23 (permalink) Old 06-04-2018, 08:48 AM
MrTrogg's Avatar
Thank's for the info, from what I can tell the valve isn't properly sync'd. I opened up the servo and gave it a spray of contact cleaner then tightened the cables, there was some noticeable slack in the lines. The valve moved smoothly by hand and was moving when turning the throttle. Had the code show up when sitting idle for a while but after refueling it didn't show up again. I'm guessing there is still some adjustment I could do on the cables....
MrTrogg is offline
post #16 of 23 (permalink) Old 06-04-2018, 08:56 AM
@MrTrogg: There are adjusters at the valve end of the cables. They adjust like a brake cable barrel adjuster. You can probably take any additional slack out at that end.
Name:  F3 Exhaust Valve Adjustment.jpg
post #17 of 23 (permalink) Old 06-04-2018, 10:41 AM
MrTrogg's Avatar
Yup, I should have been more clear. I did adjust them via that method however the loose wording in the manual suggested to not over tighten it. It's probably me just not doing it enough to get all of the slack out.
MrTrogg is offline
post #18 of 23 (permalink) Old 06-04-2018, 11:01 AM
Never said or mentioned that it are facts.
Just a quick search.
Im sure esq'z me knows a bit more about it since he mentioned he worked on motorcycles in another post I read few weeks ago.
And ofcourse the earlier comment he posted.
"Mileena"
post #19 of 23 (permalink) Old 06-04-2018, 11:20 AM
Do NOT over tighten the cables...you will damage the actuator. Only one cable actually pulls against the valve spring (which tries to open the valve...default, no cable position is full open). The other cable helps maintain proper opening position based on ECU signal. It is normal for one cable to have some slack.
The following information is based on the systems I am familiar with. I have not studied the MV system, but suspect it is the same as all the other ones out there.
There is a position sensor on the actuator. It is a 3 wire 5 volt sensor that tells the ECU where the valve is positioned, and the ECU then activates the servo motor to move the valve where it wants it.
At full open the voltage signal should be 4.2 volts +/- .3 volts. At full closed it should be 0.9 volts +/- .3 Or vice versa...I can never remember which.
You can disconnect the actuator connector and use a 9v battery to rotate the pulley to full open or full closed with the key on (yes, it will create a fault code, but that will clear when you plug it back in).
Then back probe the still connected sensor wires, adjusting the cables to achieve the correct sensor reading. You use a 9v battery so you don't smoke the actuator with big amperage from a 12 v bike battery or similar.
post #20 of 23 (permalink) Old 06-04-2018, 12:05 PM Thread Starter
PTsalas's Avatar
OK
So in my case I have a ECU studio licence with the full OEM maps as well as the MV kit maps that don't have the exhaust valve setup.
Do I run the stock maps with the exhaust valve working or do I disconnect and run the MV Kit maps that supposedly don't compromise for environmental concerns?
I bought the kit to activate the blipper, if I can get better performance with a different map then I will do so. The issue is I don't know if removing the exhaust valve is a step forward or backward?
I blame esq'z me for this. Had my mind made up until you came planting your seeds of doubt...
PTsalas is offline
You may post new threads
You may post replies
