Low in power until mid range kicks in - MVAgusta.net
post #1 of 3 (permalink) Old 04-14-2018, 05:37 AM Thread Starter
Ddingding's Avatar
Hi guys just wondering if any1 has had any issues with 312r power?crack the throttle in 1-2gear to about 5000-6000rpm and seems laboured and then takes off like a rocket!!power output seems like a 250cc and should be a lot quicker I would imagine,don’t have the mv long and this just doesn’t seem right?any help would be much appreciated
Ddingding is offline
post #2 of 3 (permalink) Old 04-14-2018, 09:06 AM
The 312R, and most other MVs have fueling issues below 4000 rpm. Couple that with some slack in the control cables and you can have what feels like a throttle issue.
Having the ECU tuned helps this immensely as does adjusting your throttle cables.
If you were to put your location into your profile, someone local could probably chime in and help.
post #3 of 3 (permalink) Old 04-14-2018, 07:05 PM
Has anyone done any work on her recently? I mean, is this a new concern, or one you have always had?
