Brutale 910 Hugger well nut size anyone? - MVAgusta.net
post #1 of 5 (permalink) Old 10-03-2017, 05:53 PM Thread Starter
I tried searching and it seems that to fit a CF hugger to my Brutale 910S I need some M5 well nuts. I should have checked when I had the wheel off at the week-end but obviously didn't, hence a quick question.
Are the well nuts M5 and how long do they need to be?
I've ordered the hugger, it doesn't come with a fitting kit.
Sundodger is offline
post #2 of 5 (permalink) Old 10-04-2017, 06:51 AM
Just a standard M5 well nut....If I remember correctly, they were about 12 mm long, 8 mm OD. The thing about well nuts is they compress as you tighten, so even a bit long is OK.
I have the instructions from mine filed away somewhere. I'll have a look around and post them if I can find them. Been 8 years though, so maybe hard to locate.
post #3 of 5 (permalink) Old 10-04-2017, 08:37 AM Thread Starter
Thanks for the response. Well nuts aren't something we can walk into a hardware store and buy over here easily so I'll probably order some from fleabay. I had thought of using rivnuts which seem to be easier to come by but I'm not keen to buy a gun just to fit three inserts. If all else fails I guess I could tap out the holes.
post #4 of 5 (permalink) Old 10-04-2017, 01:39 PM
Send Noel (The Knurl) a message. He sends stuff to OZ for other members routinely. They are cheap when you know where to get them.
Do a search for well nuts on eBay and you will finds lots of suppliers.
post #5 of 5 (permalink) Old 10-06-2017, 07:30 AM
...or you could PM me your details and I'll send you three M5 well nuts.
