ECU Reflash - Page 2 - MVAgusta.net
post #11 of 17 (permalink) Old 07-25-2017, 09:26 AM
@MarcoM3: First, your signature either says nothing, or it says 2013 F3. This does not differentiate between 675 or 800 as the 800 came into production that year. If you make me dig through your profile to find out what you want help with, good luck.
Now, as for sport v. Custom....custom is a mode that allows you to set each parameter to your liking. It is well described in the bike manual.
post #12 of 17 (permalink) Old 07-25-2017, 03:44 PM Thread Starter
MarcoM3's Avatar
My mistake on the signature. I thought it did and I was not expecting anyone to "dig through my profile".
The ECU re-flash was something a friend brought up as a fix to eliminate the rev limiter, but I am not 100% sure this is the problem. I am just looking for some help, brother. I would like to know if anyone is familiar with my specific issue and if they solved it somehow. If you have nothing to contribute (which is perfectly okay), why not move on from the thread and let others do?
MarcoM3
2013 MV Agusta F3 675
2012 Ducati Panigale 1199
2013 MV Agusta F4
MarcoM3 is offline
post #13 of 17 (permalink) Old 07-25-2017, 03:49 PM
You can lead a guy to an answer, but you can't make him see it. Good day.
post #14 of 17 (permalink) Old 07-26-2017, 07:55 AM
How about you TRY the custom mode which costs you nothing and you can still go back to sport mode if you don't like it? No need to flash your bike if changing some settings will (possibly) solve your issues.
Also are you on the latest ECU map which can be loaded onto the ECU by your dealer?
As I said, can't reproduce it on my 800...
Nephalem is offline
post #15 of 17 (permalink) Old 07-26-2017, 09:10 AM Thread Starter
MarcoM3's Avatar
I will definitely give it a try, and hopefully it will make a difference. I just got to wait for the next time I am able to get the bike up to those speeds in the right environment to see if that solved it.
Yes, I am on the latest ECU map. I shall report back, thanks for the reply!
MarcoM3
2013 MV Agusta F4
MarcoM3 is offline
post #16 of 17 (permalink) Old 07-26-2017, 01:11 PM
dudman's Avatar
Doing a little research, pic attached.
Speed limited to 162.5mph.
This must be a new thing because my 2012 F3 STD ECU definitely was not limited as got an indicated 173mph @ nurburgrin straight.
Must be MV's answer to valve failures, stop the prolonged high engine speed.
dudman is offline
post #17 of 17 (permalink) Old 08-09-2017, 05:58 AM
khosakul's Avatar
Need help. I m trying to flash my F3 800 (y2016) ecu with ECUstudio. Changed exhaust to full system, no exup and O2 sensor removed/unplugged. I opened rom file provided by EcuStudio which says "F3 800 Racing ROM" and set O2#1 and O2#2 (not sure what 1 and 2 means) to "off", then uploaded successfully to the bike. Exhaust valve fault code is gone but Lambda Fault still shows on dash. I was at dyno with my tuner when doing all abovementions. Try to get the bike properly tuned but we still not sure about tables in the EcuStudio, for example ignition Advance Vs Base1 Vs Base 2. Also another problem is when on the Dyno after uploaded the racing ROM file, the QS doesn't work both ways. (Did not try QS while bike actually runs yet)
khosakul is offline
