Indicator issue. Only work with ignition - MVAgusta.net
post #1 of 11 (permalink) Old 05-04-2017, 01:28 PM Thread Starter
I have just installed the LED Rizmola indicator mirrors with the resistors as per instruction manual, and tested with ignition on and all good.
Took for a ride today and the indicator light on dash doesnt work and nor do the indicators (all 4). Any advice? Doing my head in!
MV Brutale 920 2012 White - Current
MV F41000R 2007 Black/Silver/Red - Gone
Bikerzz is offline
post #2 of 11 (permalink) Old 05-04-2017, 02:42 PM
Have you checked the fuse?
BTW, I also tried resistors at first and found the resistors get very hot (leaving a burn mark where I mounted them). I've switched to a Badlands load balancer, and everything works perfectly (no heat).
Who moved my cheese?
MY04 Brutale 750S
Paul.RP is offline
post #3 of 11 (permalink) Old 05-04-2017, 04:57 PM Thread Starter
Cant be a fuse as they work when engine not running. Im guessing it something to do with voltage. I will check out a Badlands Load Balancer. What part number did you get?
Bikerzz is offline
post #4 of 11 (permalink) Old 05-04-2017, 07:45 PM
I got the Badlands Equalizer III (LE-03). I took (switched) power from the tail light to install it.
MY04 Brutale 750S
Paul.RP is offline
post #5 of 11 (permalink) Old 05-04-2017, 09:28 PM
sstainba's Avatar
I'm planning on swapping out my indicators soon on my 2017 Brutale 800... Where did you get this load equalizer? I'd rather use something like that then the resistors...
sstainba is offline
post #6 of 11 (permalink) Old 05-05-2017, 12:09 AM
I got them from a local motorcycle shop (they are targeted at Harleys directly, so I reckon a Harley dealer is your best bet). I've seen them on ebay and other places as well. I think you can also get them direct from the manufacturer 'NAMZ' motorcycle products, just google them.
MY04 Brutale 750S
Paul.RP is offline
post #7 of 11 (permalink) Old 05-05-2017, 03:21 AM Thread Starter
Cheers. I have the load resistors as per Rizmola instructions and they dont work, a load equaliser is just resistors in a box isnt it?
Bikerzz is offline
post #8 of 11 (permalink) Old 05-05-2017, 04:17 AM
not all LE are created equal...:-)
https://www.namzcustomcycleproducts....-91-13-models/
MY04 Brutale 750S
Paul.RP is offline
post #9 of 11 (permalink) Old 05-05-2017, 02:40 PM
perhaps have a look at what ground wire you've used - possibly once the bike is running, your 'ground' is actually a 12V supply (quite common in some lighting circuits)
Nicklemouse is offline
post #10 of 11 (permalink) Old 05-09-2017, 06:06 AM
FWIW - I installed these mirrors and just used the basic Rizoma resistors - all works just fine.
manicguitarist is offline
