Powercommander on B3 - MVAgusta.net
post #1 of 3 (permalink) Old 04-23-2017, 04:19 AM Thread Starter
MikaelBrutale's Avatar
Hi
Does anyone know if the ecu on Brutale 800RR is adjustable?
If it has to be changed or if I should install powercommander or similar. Plan is to install complete SC Project system and airfilter.
Mikael
_______________
Brutale 910S Challenge for track, Brutale 1090RR
MikaelBrutale is offline
post #2 of 3 (permalink) Old 04-23-2017, 05:36 AM
eddypro's Avatar
http://www.mvagusta.net/forum/21-cus...-question.html
This might Help You, One thing that could be an issue is the first 20 percent throttle position might not be tunable because this would be due to your ecu ,I have no idea if they make a race ecu for your bike ,this disable the Lambda sensor , so in effect then you could tune the whole range 0 to 100 percent throttle position, You really would have to talk to Dyno Jet. or a Tuner .
cheers eddy
eddypro is offline
post #3 of 3 (permalink) Old 04-23-2017, 04:24 PM Thread Starter
Great!
_______________
