How to make the F3 Gp style shift and keep the stock look? - MVAgusta.net
 3Likes
post #1 of 21 (permalink) Old 03-19-2017, 08:28 PM Thread Starter
R1andrew's Avatar
I know on the F4 I could and did switch the drum to keep the stock look and have the gp style shift pattern. Can I do something like this on the F3? I want to keep the Ago stock looking while having Gp style shifting. The linkage arm must stay where it is at and run through the frame.
R1andrew is online now
post #2 of 21 (permalink) Old 03-19-2017, 08:46 PM
Tasty F3's Avatar
I don't know about changing the shift drum but CNC make an "adapter" to change your stock rear set to GP shift by changing the foot control, this also move the shift rod from through the frame plate to a more vertical position.
CNC Racing F3 Reverse Gear
Chris
Tasty F3
2012 F3 675
Tasty F3 is offline
post #3 of 21 (permalink) Old 03-19-2017, 08:46 PM
Haven't seen any yet Andrew ..... but will look around for you.
post #4 of 21 (permalink) Old 03-20-2017, 02:19 PM
hb88xx's Avatar
these must be the oposite of each other
SATO RACING | Rear Sets - MV Agusta F3 ('12- )
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
post #5 of 21 (permalink) Old 03-20-2017, 09:32 PM
Andrew doesn't want to relocate the shift link from the frame Hans, he's looking for a reverse shift drum like we use on the <2010 bikes.
post #6 of 21 (permalink) Old 03-21-2017, 05:26 PM
Exclamation ?
You can flip the bellcrank 180 but the quick shifter won't like it
post #7 of 21 (permalink) Old 03-21-2017, 07:56 PM Thread Starter
R1andrew's Avatar
Not enough space for that.
Donsy and Donsy like this.
post #8 of 21 (permalink) Old 03-22-2017, 01:56 AM
then use a shorter bell crank.......This isn't rocket science.....
but I don't know if the pressure transducer will like it or not, does it quick shift up and down?
Why "GP" shift...... because your toe is under the lever.... WTF
Raise the peg and move it to the rear ...... problem solved.....
Look at Jarno Saarenin's bars and levers.....
even Steve McLaughlin figured that shit out in the '70s..... I was his wrench
post #9 of 21 (permalink) Old 03-22-2017, 06:33 AM
Lightbulb
You're not looking at the original configuration Noel, the pics above are aftermarket models
And no, the quickshifter will not read both ways on this model, but that can be sorted.
Many older bikes actually did use reverse shift or right foot shift.
post #10 of 21 (permalink) Old 03-22-2017, 07:29 AM Thread Starter
R1andrew's Avatar
I have been shifting 1 up and 5 down on all my bikes for over 10 years now.
quick shift on this model works for upshifts. And why do I want to change it? Missing a shift is not fun and even less fun in the corner
You may post new threads
You may post replies
