2013 f4rr bodis slipon install questions - MVAgusta.net
post #1 of 4 (permalink) Old 02-19-2017, 11:08 PM Thread Starter
Hi all - recently purchased the bodis slip on for my bike!
I wanted to know if anyone has got a set of instructions for the install or there is a forum post somewhere which goes through it?
I dont have anything with the pipe.
Also - Bodis told me simply to tie up the cables to get rid of the "exhaust valve error", is this correct? The below is their message:
"In the original exhaust, there is a valve in the exhaust.This valve is controlled by a small engine through cables. Please remove that cables from the engine, but leave the engine in the bike and leave it electrically connected.Then there will be no error message from the bike."
My dealer told me that this wont work. Does anyone have experiences with this?
Thanks all!
flynhi2016 is offline
post #2 of 4 (permalink) Old 02-20-2017, 01:14 AM
Fragile's Avatar
My stock system started faulting probably due to sticking in the rainy ride and I tied off the cables to the left lower fairing bracket after disconnecting from the valve on the pipe. No more faults.
'15 Panigale R (2K miles)
'15 Fireblade SP (1K miles)
Los Angeles North
Fragile is offline
post #3 of 4 (permalink) Old 02-20-2017, 01:17 AM
Yes, you disconnect the cables between the exhaust and servo motor, do not disconnect the wiring to the servo motor.
post #4 of 4 (permalink) Old 02-22-2017, 09:34 AM
^^^ +1 The sensor is at the servo. Keep it connected to the wiring without the cables and there will be no error message.
2014 F4 RR
2008 Yamaha Raider S
1982 Suzuki GS850L
fingertight is offline
