new LED tail light - MVAgusta.net
post #1 of 9 (permalink) Old 12-26-2016, 09:28 AM Thread Starter
number2's Avatar
new LED tail light
It has 1 wire for each turn signal and the stock turn signals have 2 wires. What do I do with the second wire? I guess just put a wire cap on them
number2 is offline
post #2 of 9 (permalink) Old 12-26-2016, 09:52 AM
Does the new unit ground to the frame?
post #3 of 9 (permalink) Old 12-26-2016, 10:24 AM
gordo555's Avatar
With only one wire, it would seem it has to... It would presumably also need a resistor to load the relay.
2006 Brutale 910S.... runs like a scalded assed ape.
gordo555 is offline
post #4 of 9 (permalink) Old 12-26-2016, 11:10 AM Thread Starter
number2's Avatar
tried a test run and ground comes from the circuit for the tail light plus no resistor seems to be needed. The turn signal flashed at a normal pace. Design Corse comes through again with a terrific product
number2 is offline
post #5 of 9 (permalink) Old 01-01-2017, 02:31 PM
Can you link to the one you got please mate. Ive had some bad luck in past with these LED lights and want one for my B4
MV Brutale 920 2012 White - Current
MV F41000R 2007 Black/Silver/Red - Gone
Bikerzz is offline
post #6 of 9 (permalink) Old 01-01-2017, 03:45 PM Thread Starter
number2's Avatar
Design Corse sells it
https://www.designcorse.com/collecti...ghts/mv-agusta
number2 is offline
post #7 of 9 (permalink) Old 01-03-2017, 12:19 AM
fasduc's Avatar
George, did you cut the original turn signal connectors off and hard wire to the singel wire from the LED tail light? Which original wire of the 2 did you use?
I bought the same tail light from DC for my '12 1090RR.
fasduc is offline
post #8 of 9 (permalink) Old 01-03-2017, 09:32 AM Thread Starter
number2's Avatar
The LED signals get ground through the tail light circuit of the new assembly so you only need 1 wire. I just touched the wire for the LED signal to the wires on the plug coming out of the bike harness until the signal started flashing. I believe it is the male pin on the plug coming out of the harness. I cut the plug off of the stock signal and soldered it to the wire coming from the new tail light assy. You do not need to do anything with the second wire except secure it.
You might notice it flashing a tad bit slower than stock but it isn't enough to worry about. If this isn't clear then you cal message me and I will give you my phone number
number2 is offline
The Following User Says Thank You to number2 For This Useful Post:
post #9 of 9 (permalink) Old 01-03-2017, 04:45 PM
fasduc's Avatar
Thanks George!
fasduc is offline
You may post new threads
You may post replies
