cush drive weights ... - MVAgusta.net
post #1 of 1 (permalink) Old 11-15-2016, 08:26 PM Thread Starter
Thumbs up cush drive weights ...
all weights without sprocket and bolts but with 2mm washer
2nd version (flat sprocket ) 1.080kg
2nd Gen '10 + 1.130kg
FBF replacement for the 1st version (rubbers in the sprocket ) 880g
so in other words you save 200g on the cush alone, add to that the FBF
uses bolts instead of nuts and bolts, add to that an alloy sprocket
a stock MV 40 tooth 525 sprocket and nuts and bolts weighs 640g
sorry the alloy FBF i have isn't a 40/525 and is very worn
aluminum weighs ~1/3 that of steel so I should lose ~700 g
You may post new threads
You may post replies
