RR vs R Power commander?? - MVAgusta.net
post #1 of 9 (permalink) Old 11-01-2016, 05:31 PM Thread Starter
So I have a 2007 F4 1000 R 312 with the 5sm ecu, Power commander lists the 2009 RR 312 only, does anyone know if the power commander work for my bike?
tim_fc3s is offline
post #2 of 9 (permalink) Old 11-01-2016, 06:00 PM Thread Starter
Nevermind, I found the one I need, it is the PCIII 730-411. I was just looking at the wrong part of their website.
tim_fc3s is offline
post #3 of 9 (permalink) Old 11-02-2016, 08:02 AM
Tim, why use a Power Commander?
Why wouldn't you simply have the ECU tuned?
post #4 of 9 (permalink) Old 11-07-2016, 01:16 PM Thread Starter
Is that what you would recommend over the PC? it seems to be roughly the same cost, but with out dyno tuning. I was planning on having the bike tuned with the PC.
tim_fc3s is offline
post #5 of 9 (permalink) Old 11-07-2016, 01:56 PM
Power Commander can do nothing for the timing tables. Retarded timing is the primary reason the MV runs hot.
Dyno tuning all three axes of the fuel/air/timing charts is what creates optimal performance.
post #6 of 9 (permalink) Old 11-09-2016, 03:43 PM
number2's Avatar
I have been both routes and the ECU remap is the best although I went with the Microtec. The Power Commander is nowhere close to the Microtec so if you can swing the cash go that route
number2 is offline
post #7 of 9 (permalink) Old 11-09-2016, 07:21 PM Thread Starter
Which microtech are you using? Did you see much on terms of power increase?
tim_fc3s is offline
post #8 of 9 (permalink) Old 11-09-2016, 08:36 PM
number2's Avatar
Right now not sure of the model number (I have a 2009 F4) but it makes the bike run so smooth it is unbelievable and it runs so much cooler. The Power Commander I had on my Brutale actually made the bike run worse.
number2 is offline
post #9 of 9 (permalink) Old 11-09-2016, 09:49 PM
Post
MICROTEC - M226 is what you'll need. Ask this guy - http://www.mvagusta.net/forum/member.php?u=3979
Other details for him in the 1st post here - http://www.mvagusta.net/forum/showthread.php?t=75945
You may post new threads
You may post replies
