How to access IAW 16M board - MVAgusta.net
post #1 of 6 (permalink) Old 10-12-2016, 03:43 PM Thread Starter
Hi,
The Diag socket on my F4 ECU IAW 16M doesn't work. The connectivity is all right. does anybody knows :
1 if it's possible to get access to the electronic board?
2 how to extract it from the box?
Best regards
Dini is offline
post #2 of 6 (permalink) Old 10-13-2016, 06:27 AM
In what way doesn't it work ?
merc07 is offline
post #3 of 6 (permalink) Old 10-13-2016, 09:28 AM Thread Starter
I made several attempts to connect on the ECU with my laptop without success. My reseller tried to connect too with his own equipment. same result. The problem is that the inlet parameters are very bad from 4500 to 7000 rpm making a huge whole at the acceleration. I need a connection to reset the tps and/or check the health of the different devices.
I'm suspecting a defect of the board preventing me to make the connection.
Dini is offline
post #4 of 6 (permalink) Old 10-13-2016, 09:52 AM
What software are you trying to connect with ?
Also, there is no tps reset as such but is is easier to display the tps with software while you manualy adjust.
merc07 is offline
post #5 of 6 (permalink) Old 10-13-2016, 11:41 AM Thread Starter
I tried with Ducatidiag and guzzidiag.
I don't know what is the reseller software but a third one for sure.
During the connection, the computer just send an "AT0" request to the ECU throught the diag socket. It expects to receive an aknowlegment from the ECU (OK). As the computer doesn't receive the "OK" from the ECU the connection is in failure.
https://www.elmelectronics.com/wp-co...7/ELM327DS.pdf for more information on AT commands
Dini is offline
post #6 of 6 (permalink) Old 10-18-2016, 05:58 AM
Are you sure it is a 16M, not 5SM, your profile shows a 1078 ??
merc07 is offline
You may post new threads
You may post replies
